Aftermarket Stereo connection
Old Apr 9, 2025 | 04:54 PM
gjohnson's Avatar
gjohnson
Default Aftermarket Stereo connection
Installing aftermarket stereo in my 76.OEM has a 3 wire connection Yellow/power black/ground and grey? Is the grey wire ignition?Thanks
Old Apr 9, 2025 | 07:05 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
It is for the lights on the radio, not used on aftermarket I think.
Old Apr 9, 2025 | 10:49 PM
s carter's Avatar
s carter
I just installed a aftermarket radio in my 81 for around $10 I bought a harness set that you splice the Harness to the new radio and you can then plug into the factory car harness if you have crazy speakers and amps you can run those wires separately but all the radios power needs are covered.
Old Apr 10, 2025 | 07:35 AM
Piersonpie's Avatar
Piersonpie
My very first thread, enjoy.
Custom Autosound Radio wiring on 1976 corvette
Old Apr 10, 2025 | 05:34 PM
gjohnson's Avatar
gjohnson
Thanks for the replys!!
Old Apr 10, 2025 | 09:08 PM
7T1vette's Avatar
7T1vette
Gray is usually dash lights wiring in Chevy harnesses. Also, for early-mid year C3's, the speaker connections are 1) signal and 2) chassis ground. Newer aftermarket radios do not have grounded speaker leads. Both leads come from the head unit for each speaker.
To Aftermarket Stereo connection
