Temperature gauge
Old Apr 13, 2025 | 10:58 AM
BanjoTim's Avatar
BanjoTim
Cruising
Default Temperature gauge
I am wondering if anyone knows why my new temp gauge is not working it will advance to 120-130 degrees when driving though stops there, I have a temp gauge on my radiator cap that reads otherwise up to 190 degrees. 1977 C3 Thanks, Tim
Old Apr 13, 2025 | 01:02 PM
MelWff's Avatar
MelWff
Did you also replace the sender in the driver's side cylinder head?
Old Apr 13, 2025 | 05:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Tim,
Your gauge on the Rad is mechanical and somewhat reliable. Few people feel the need for a gauge at that location.
Your electrical temp gauge indicates it's trying to work but has a fault. And that fault is most likely a poor ground.
And that is exactly what the single wire going to the sender is. A ground wire.
With any luck, it's just some dirt, grime, grease on the senders connector.
Usually, a good degreasing and a little sandpaper on both the sender and the wire terminal will bring the better grounding into play.
Old Apr 13, 2025 | 06:32 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Did your old temp guage work? If not did you test anything to determine why it didn't work? Green wire connected to the sender between cylinders 1 and 3 in head? Have you tested by putting green wire to ground? Results?
Old Apr 13, 2025 | 11:37 PM
7T1vette's Avatar
7T1vette
Sending unit should not have non-conducting sealant or teflon tape on the threads. That threaded joint is the electrical ground connection for the circuit. Also, "new" (aftermarket) gauges and sending units are notorious for being poorly calibrated.
To Temperature gauge
