1969 Quadra Jet question
Old Apr 16, 2025 | 02:18 PM
bmac57's Avatar
bmac57
Default 1969 Quadra Jet question
Does anyone know the correct size metering rods and jets that should be in the Quadra Jet carburetor on my '69 L-36 427? Also is there any difference in the power piston springs? My Vett is a 4 speed with factory air, if that makes any difference.
Old Apr 16, 2025 | 03:16 PM
Piersonpie's Avatar
Piersonpie
A 4 speed L36 is 7029215, correct?
71 primary jets, 45 primary rods, AX secondary rods.
I don’t know the spring used, but I’m sure @lars does.
Old Apr 16, 2025 | 04:43 PM
QIK59's Avatar
QIK59
I believe there were 3 different springs used in Q'jets but Lars will be able to tell you which one you should use.
Old Apr 17, 2025 | 02:04 PM
bmac57's Avatar
bmac57
Thanks, that gives me a good start. I'll try to get hold of lars on spring selection.
To 1969 Quadra Jet question
