Replacing drivers door hinge.
Old Apr 21, 2025 | 09:36 PM
Chagjr's Avatar
Chagjr
Default Replacing drivers door hinge.
I plan on purchasing a new hinge for my 68 from Corvette Central.
Is this a pretty straight forward swap? Is there any alignment concerns or additional parts I should need?
I have looked at some videos, I understand the process, I am looking for what others have encountered with their 68 Vette doing the hinge replacement.
Old Apr 22, 2025 | 12:54 AM
forman's Avatar
forman
Why don’t you just replace the bushings
Old Apr 22, 2025 | 05:58 AM
jhudec's Avatar
jhudec
Also, be aware 68 and early 69 hinges are a bit slimmer and a replacement may not slide into the door.
joe
Old Apr 22, 2025 | 08:41 AM
Chagjr's Avatar
Chagjr
The top hinge is junk. At some point an owner did the old weld stop. The hinge is now moving past the weld stop.
I have repaired the door edge twice now.
the lower hinge has the “V” cut.
Old Apr 22, 2025 | 08:45 AM
Chagjr's Avatar
Chagjr
joe
Thank you for this tidbit of information. I just hate surprises.
Old Apr 22, 2025 | 10:00 AM
forman's Avatar
forman
Yeah the top is a little bit of a bitch to get out you might have to take the panel and drop the wheel to get to it
To Replacing drivers door hinge.
