Fires once or twice, doesn’t start
Old Apr 26, 2025 | 02:07 PM
Grondin77's Avatar
Grondin77
Cruising
Originally Posted by MelWff
Yes, in my case it's black plastic, 2 pieces, with 8 slots. You are sure it's Mallory?
Also 73 never had HEI, points from the factory, you have 12v cranking but have a resistor wire for run. If you never touched the positive terminal of the coil it would be unusual for something to have suddenly changed.
I believe it is only the Mallory module, it looks the exact same as a normal point distributor except where the points would be it’s a single red module. That why I’m very confused on why it all the sudden won’t run, the wiring under the hood is all over the place don’t really know what my uncle did. I will have to print out a starting diagram and see if that is the problem.
Old Apr 26, 2025 | 02:38 PM
Grondin77's Avatar
Grondin77
Cruising
Quick update, I have one of those accel super coil packs and I just tested for voltage with key set to on. I used a multimeter on the positive and negative terminal on the top of the coil pack, it only read 1.9 volts, is it supposed to be 12v on my multimeter between those points or no? I also kept the meter on those points and had someone crank the motor and it still didn’t go over 2 volts, is my problem in there?
Old Apr 26, 2025 | 02:43 PM
MelWff's Avatar
MelWff
Originally Posted by GruntyPants
Can you verify that you have power to your distributor when the key is in the 'run' position? This car should be 'new' enough to have had an HEI distributor, which did away with the resistance wire, but if an old-school guy got in there, who knows how it's wired.
Sounds like you're getting the full 12v from the (purple?) wire coming up from the starter to the (coil/distributor) but then goes away when you release the key from the 'start' position. So it will kick off when the starter is engaged, but then die when released.
So, just make sure you're getting full 12v power to your coil/distributor with the key in 'run' and in 'start'
Good luck!
1973 used points and condenser
Old Apr 26, 2025 | 03:15 PM
HeadsU.P.'s Avatar
HeadsU.P.
Someone,
Get that PCV Valve hose off of the PB Brake booster line! The booster MUST HAVE a dedicated vacuum line from a good vacuum source to the booster,
WITHOUT any other accessories plumbed into it, solo.
You may lose your braking one day.
Old Apr 26, 2025 | 03:55 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
deleted
Old Apr 26, 2025 | 08:35 PM
Chambered's Avatar
Chambered
Try a different rotor & cap. One of the new parts may be bad already. I'm hearing stories like this about almost everything.
Old Apr 26, 2025 | 08:58 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Originally Posted by HeadsU.P.
Someone,
keep looking! See the plastic fuel filter bouncing on the front of the engine and the rubber fuel lines? And yes that vacuum line set-up is some kind of wonderful. So, yes, just how is the wiring for the ign. System?
