U joints popping out
https://www.corvetteforum.com/forums...ual-l82-2.html
are you sure the spring clip is tight in the seat? Make sure very clean and it is pressed in.
did you use a backer plate as well to not bend flange.
also make sure french locks are in place.
Also make sure that you are not forcing the cup inward while seating the clip. If you have to force it, you need to identify (and correct) the reason.
I couldn't identify the problem, and friends of mine, also mechanics by trade couldn't see the problem. New U joints didn't solve the problem.
SO, I took the half shafts and the flanges to a shaft shop and asked to have them balanced .
Long story short. They found the problem in less than 10 minutes. As soon as they spun them.
So, my advice, take that half shaft and that flange to a proper drive shaft shop. Have them replace that joint and ask them to balance the shaft. If anything is twisted. They'll find it.
