Locks
Old Feb 12, 2003 | 09:13 PM
SCVetteGuy's Avatar
SCVetteGuy
Default Locks
As it is my car only locks by using the key on both doors. The power locks don't work, the locks inside don't work. This is quite a hassle, as I'm sure you can imagine. :mad I would like to know how much it would cost to get them working again, and how hard it would be to do. I don't have to have the power locks working, but it would be nice. Any info you can provide is appreciated. :cheers:
Old Feb 12, 2003 | 09:25 PM
wombvette's Avatar
wombvette
Default Re: Locks (SCVetteGuy)
Usually its because the plungers on the Power Locks are dry and stiff. You can oil them up and most will go back to working. Oil them under the rubber boot. Or you should be able to remove the conector rod and take the power activator loose. Lube all of the moving parts in the system.
Old Feb 12, 2003 | 09:34 PM
StingRay327's Avatar
StingRay327
Hope you like building ships in a bottle, because that's what it'll be like if you need to do anything to the locks on the inside of the doors. :D
Old Feb 12, 2003 | 11:59 PM
80Xflags's Avatar
80Xflags
Default Re: Locks (StingRay327)
:iagree:
Do your best not to drop any of the tiny retaining clips into the abyss :rolleyes: . If you do, I found that a clean, bagless vacuum works, or sometimes a magnet on a shaft. Goodluck.
Old Feb 13, 2003 | 07:56 AM
SCVetteGuy's Avatar
SCVetteGuy
Default Re: Locks (80Xflags)
Sounds like this will be fun! But its something I really want to get done, It'd be nice to leave stuff in my car!! Luckily my dad has one of those magnets on a shaft, so maybe we won't have too much of a problem. :banghead:
Old Feb 13, 2003 | 08:58 AM
Ganey's Avatar
Ganey
... The power locks don't work, the locks inside don't work. ...
Sounds like a rod may be disconnected so you need to take a look.
To Locks
