rag joint
Old May 9, 2025 | 03:47 AM
garykuter's Avatar
garykuter
Default rag joint
Do I need the torque down the bolts that go on the rag
joint? And if so, what’s the torque on them and do I tighten all of them down to the torque specs?
Old May 9, 2025 | 06:35 AM
ctmccloskey's Avatar
ctmccloskey
When I installed my new Rag joint I simply cranked them down to ~25 foot pounds and they have never come loose since then. The object is to have them tight enough to not come loose by accident. Never been a problem.
Old May 9, 2025 | 06:45 AM
garykuter's Avatar
garykuter
so all the bolts need to be tightened down right? And not in any kind of sequence, correct?
Old May 9, 2025 | 07:22 AM
TurboTodd's Avatar
TurboTodd
Yes, Clamp bolts (blue) 30 ft lbs. The others as mentioned (green) 20 ft lbs. I also used a drop of blue loctite for added peace of mind.
Old May 9, 2025 | 09:08 AM
GTR1999's Avatar
GTR1999
That rag is ripped, why are you using it?
Old May 9, 2025 | 05:49 PM
garykuter's Avatar
garykuter
you’re right it is ripped. I just overlooked it I guess.
Old May 9, 2025 | 05:50 PM
garykuter's Avatar
garykuter
can I just buy the part that is ripped?
Old May 9, 2025 | 07:05 PM
garykuter's Avatar
garykuter
do I need to take off my steering box to put this joint on?
garykuter's Avatar
garykuter
do I need to take off my steering box to put thisjoint on?
Old May 10, 2025 | 02:44 AM
Haggisbash's Avatar
Haggisbash
You can make the flexible part out of a piece of conveyor belt if you can't find one.
Old May 10, 2025 | 03:08 AM
garykuter's Avatar
garykuter
OK, thank you. More read up on this joint the more I don’t wanna do it. Looks like a total pain to replace.
Old May 10, 2025 | 03:49 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Come on Gary, it's really not hard at all.
Old May 10, 2025 | 04:35 AM
garykuter's Avatar
garykuter
ok fly out to Vegas and I'll pay you to do it. LOL Guess if I can rebuild a block I can do this.
Old May 10, 2025 | 05:09 AM
4-vettes's Avatar
4-vettes
Degree of difficulty on this is maybe a two. I think I described the process fairly well in your other thread. It's a half hour job Mate!
Old May 10, 2025 | 08:58 AM
GTR1999's Avatar
GTR1999
The thing to remember is the column from 67-82 is collapsible so you don’t want to put pressure on the column as in using a pry bar to get the column flange up
Old May 10, 2025 | 09:03 AM
Lt.Mike's Avatar
Lt.Mike
My thought too .
Just buy the factory replacement joint from Zip and be done with it.
It’s an easy job. Unbolt the column from the joint then from the dash and firewall and pull it back about an inch and install the new joint. Bolt it all back up. Btw, stay with the original joint and stay away from poly .
Old May 10, 2025 | 12:27 PM
7T1vette's Avatar
7T1vette
Whichever way you go, the ragjoint actually transfers electrical ground up and into the horn circuit. GM flex disc had mesh wire built into it for this purpose. If you replace the disc with one which does NOT have mesh in it, you need to create a ground path from one side of the ragjoint to the other. Braided copper ground-strap is one option to get that done.
To rag joint
Old May 10, 2025 | 08:29 PM
augiedoggy's Avatar
augiedoggy
no.
Old May 10, 2025 | 08:31 PM
augiedoggy's Avatar
augiedoggy
its not that bad ive done it twice now.. Just prespray with penetrating oil. I went against the grain here and put a poly joint on my car a couple years ago. I used a regular rubber joint on my uncles car. no issues with either yet.
Old May 11, 2025 | 03:58 AM
garykuter's Avatar
garykuter
Originally Posted by Lt.Mike
My thought too .
good to know thank you
