New intake manifold install question
Yes there is always coolant in the forward part of the intake manifold.
Or, look at Summit Racing.
They have black, blue, red, stainless, chrome that looks nice on aluminum Intakes.
A very small dab of Permatex Waterpump & Waterneck (AutoZone $9) applied to the plug's threads will prevent future dribbles.
That sealant is Glycol Proof. Several sealants are not.
Just "snug the plug". No more torque than necessary or you could damage the casting.
To see pictures of plug options, click on my avatar to the left.
Look for an album Eddy Air Gap.
Depending on your Intake model, it may or may not have two more waterports in the rear of the Intake.
The two in the front I believe were 1/2 inch NPT?
The two in the rear were maybe 3/8 inch NPT?
Don't remember.
But keep in mind NPT plugs are NOT the actual size of the threaded hole.
Why Didn't You Tell Me It Wouldn't Fit? (disclaimer)
There are ways to make it work. Even with the tall 7501 Air Gap.
just kidding.
Open style Air Cleaner, 1.5 inch drop base, (chrome, more H.P.)
The base is specific for Holley 4150s because it has indentations for the fuel bowl adjustment screws.
Then, thru NAPA, an element that is 14" dia and 2 & 5/8 inches tall.
NAPA p/n Fil 6037
Then a rubber insulating spacer from Holley which is 0.260 thick including the aluminum heat shield.
Tip:
Remove the carbs air cleaner stud before test closing the hood. You may have to shorten the stud for the wingnut to clear.
I have 3/8 of an inch hood clearance.
I also have solid motor mounts. That air cleaner is not going anywhere under torque conditions.
Go to Walmarts toy section and get some Silly Putty. It will leave a lasting impression.
Place a couple globs strategically on your air cleaner. Slowly close the hood.
Check the putty thickness.
If you booger up the hole too much, don't worry, you can drill it larger and install a heli-coil.
This is part of being a mechanic, live and learn.
I don't have much clearance as one side of my air cleaner has about 1/4 inch space according to the clay method. I had it on my dual plane but it just didn't run right. I installed the single plane and it really woke it up,
