82 Vette speedometer needle sticking
Old May 19, 2025 | 05:13 PM
J Robison's Avatar
J Robison
Default 82 Vette speedometer needle sticking
My speedometer works perfect then the needle will stick at 20 mph when I slow way down or stop. It works fine at any speed above 20mph. If I gently tap the cluster clear cover the needle will fall to zero. I have had speedometer serviced and had a new cable installed bypassing the cruise control. Any suggestions on how to clean it? I don’t want to spray cleaner and do something bad.
Old May 19, 2025 | 07:57 PM
Fly skids up!'s Avatar
Fly skids up!
Remove the speedometer and blow it out with compress air. A drop light oil on each of the needle shaft.
Old May 19, 2025 | 09:29 PM
J Robison's Avatar
J Robison
Thank you
To 82 Vette speedometer needle sticking
