Lower A Arm bushing
Old Jun 3, 2025 | 12:12 PM
777max's Avatar
777max
Default Lower A Arm bushing
Hey,
Its me again. I cant get my lower A Arm Bushing Out. Got IT Out a bit with the Tool i used for the upper ones but IT doesnt get any further. Does anyone know a good Trick to get em Out? Drilled Most oft the Rubber Out and tried IT with an Air chisel, didnt Work. Sprayed IT with Pb Blaster today and will try again tomorrow.
Old Jun 3, 2025 | 12:34 PM
sunflower 1972's Avatar
sunflower 1972
Burn them out with a propane torch. Starts at the 13 minute mark.
Old Jun 4, 2025 | 12:31 AM
RC81's Avatar
RC81
Thats how I did mine.
Old Jun 4, 2025 | 04:47 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I burnt mine out with oxy/acetylene. Makes a lot of black smoke.
Old Jun 4, 2025 | 09:02 AM
interpon's Avatar
interpon
I would try air chisel again. focusing on the pic area to get metal part off and chisel out the rest. Use a socket to support. It took me a few tries.. post 6-7-8 were most helpful for me.
https://www.corvetteforum.com/forums...rs-method.html
Old Jun 4, 2025 | 09:05 AM
GTR1999's Avatar
GTR1999
I've never had to burn them out, air & hand chisels always worked for me, but there's always the one that is harder than most I suppose.
Old Jun 4, 2025 | 01:23 PM
777max's Avatar
777max
I burned the Rubber Out and the Metal part on the shaft was easy to get of with a Hand chisel after The Rubber was burnt. The rest is still stuck, will have to try again. Any ideas on how to get the Metal sleeve Out? Maybee chisel on the Part of the outer sleeve you See from the underside of the a Arm to try and Break IT free? Now that the Rubber is gone there should be some room for IT to bend right and maybee Break loose?
Old Jun 5, 2025 | 05:21 AM
4-vettes's Avatar
4-vettes
yes but burning them out is quick and easy and no bending of the arms.
Old Jun 6, 2025 | 06:17 AM
777max's Avatar
777max
Just won the fight. I guess i was to afraid to mess Things up. Thanks for your Help, i really appreciate IT. Now comes the fun Part, cleaning 50 year old gunk from all the parts.
To Lower A Arm bushing
