1968 427 Block numbers
Old Jun 27, 2025 | 11:17 PM
9forty's Avatar
9forty
Default 1968 427 Block numbers
Hello all.
I am new to this board, and new to the Corvette world as I just bought my 1968.
I do have a question: in front of the passenger side cylinder head are the letters/numbers : T0108IR... does anyone know what this is?
I look forward to meeting everyone and thank you all for your help!
Old Jun 27, 2025 | 11:49 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Welcome!
There should be two series of stamps on that pad. Part of the VIN and the engine assembly plant, date, and option. The number you provided is the engine plant stamping. The other stamp should be 9 characters that begins with 18S4xxxxx where the last 5 match the last 5 of the vehicle's VIN.
T0108IR means Tonawanda, 0108 = January 8th, and IR means it was a 427 assembled as a 435 hp, triple 2-barrel carb/intake with manual transmission.
18S4xxxxx means 1=Chevrolet, 8=68, S=St. Louis, 4=just a place holder that all '68s used.
Old Jun 28, 2025 | 02:00 PM
69L88's Avatar
69L88
Tonawanda is a city in New York State, north of Buffalo. GM built the Tonawanda Engine factory there in the late ‘30s. All of the big block engine for our cars were built there.
Old Jun 28, 2025 | 03:42 PM
9forty's Avatar
9forty
Originally Posted by barkingrats
Welcome!
Thank you for that information! this is very helpful because that is exactly what it is supposed to be.
I was curious as to what those numbers would mean because the previous owner told me that this was supposed to be a factory replacement block because the original owner blew up the original engine. And if it is a factory replacement, will the other stamp still show the last 5 of the VIN?
Thanks again!
Old Jun 28, 2025 | 03:43 PM
9forty's Avatar
9forty
Gotcha! thanks!
Old Jun 28, 2025 | 07:01 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Take a photo and post the image will help with you getting the best answer.
Old Jun 28, 2025 | 07:18 PM
barkingrats
Thanks again!
Those were actually called warranty replacement engines. A warranty replacement engine (block w/crank, pistons, camshaft) came from Chevrolet with a stamp only showing a CE prefix before a series of numbers (possibly a single letter A, or B, or C...) indicating where in the warranty engine sequence this one falls for the year it was made. The CE blocks did not have a VIN sequence on them - unless someone at the dealership or a machine shop added it later. These sorts of stamps are easy to spot compared to the stamps done on the assembly line at St. Louis.
An engine pad could be restamped in its entirety in order to imply that it has the original stamps. These can be very easy to very difficult to ascertain depending on the skills of deception of the person doing the stamping. Post a clear, sharp photo as PJO suggested.
Old Jun 28, 2025 | 07:48 PM
9forty's Avatar
9forty
Here is the one on the front of the block … I haven’t found the other stamp yet.
Old Jun 28, 2025 | 11:57 PM
barkingrats
I hate to say this, but that's a restamped block (after it was decked by a machine shop). The character alignment and spacing is too variable for how Chevrolet engines were stamped at the engine plants. I'd say the story you were told about a replacement is likely true, but it's not a warranty replacement from Chevy. That you don't see the VIN stamping to the right of this one confirms it's not original to this car.
You can look for further clues as to what your engine is by posting the long casting number on the rear, top of the bellhousing flange on the driver's side. Then look for the casting date - it may be on the lower block wall, middle of the passenger side - in front of the starter or on the passenger flange opposite the casting number. If you pull the valve covers, you'll find the head casting numbers and dates.
Old Jun 29, 2025 | 12:41 AM
9forty's Avatar
9forty
well, I’ll take your word for it.
I’ll take a look at those casting numbers and let you know what I find.
He also gave me a booklet that came along with the owners manual with the word “replacement” stamped on the cover, if it means anything… I think he said it was associated with the engine.
Old Jun 29, 2025 | 08:59 AM
stingr69's Avatar
stingr69
That Corvette may have had its engine replaced under warranty, but the block that is in there now does not have an original engine stamping. You still have a great car, but this replacement engine would be a bit disappointing if you previously believed it was something else.
Old Jun 29, 2025 | 09:26 AM
9forty's Avatar
9forty
Agreed indeed. But as long as it is an L71 under the hood I guess I can live with it LOL!
Thanks guys!
Old Jul 1, 2025 | 10:05 PM
9forty's Avatar
9forty
These are the numbers behind the driver side engine head on bellhousing flange... Looks like 3916321?
Old Jul 1, 2025 | 10:21 PM
69L88's Avatar
69L88
The 3916321 block is correct for a 68 Corvette but I have read where it may have also been installed in Impalas.
Old Jul 1, 2025 | 10:23 PM
9forty's Avatar
9forty
Interesting.
Thanks for that information!
Old Jul 2, 2025 | 12:13 AM
barkingrats
Yep, looks like the 3916321 427 2&4 bolt mains block was only used in 1968 but in quite a variety of engine horsepower options: 385hp, 390hp, 400hp, 425hp, 430hp, 435hp. For Corvettes those would have been the 390, 400, & 435 for regular optioned cars while the 430 sounds like an L-88.
Old Jul 2, 2025 | 12:17 AM
9forty's Avatar
9forty
Yep, looks like the 3916321 427 block was only used in 1968 but in quite a variety of engine horsepower options: 385hp, 390hp, 400hp, 425hp, 430hp, 435hp, 2&4 bolt mains
well that’s good news then!
I appreciate your help guys! Thanks!
To 1968 427 Block numbers
Old Jul 2, 2025 | 11:13 AM
69L88's Avatar
69L88
At the end of the day, it’s still a 427 Corvette!
Old Jul 2, 2025 | 11:15 AM
9forty's Avatar
9forty
Indeed it is!
Old Jul 2, 2025 | 11:21 AM
9forty's Avatar
9forty
[QUOTE=barkingrats;1608915582]Those were actually called warranty replacement engines. A warranty replacement engine (block w/crank, pistons, camshaft) came from Chevrolet with a stamp only showing a CE prefix before a series of numbers (possibly a single letter A, or B, or C...) indicating where in the warranty engine sequence this one falls for the year it was made. The CE blocks did not have a VIN sequence on them - unless someone at the dealership or a machine shop added it later. These sorts of stamps are easy to spot compared to the stamps done on the assembly line at St. Louis.
An engine pad could be restamped in its entirety in order to imply that it has the original stamps. These can be very easy to very difficult to ascertain depending on the skills of deception of the person doing the stamping. Post a clear, sharp photo as PJO suggested.[/QUOTE
Does anyone know if they wrote or stamped anything on the factory warranty book that came with these cars if a block was indeed replaced?
The warranty book with this car has “Replacement” stamped on the cover… I wonder if this has anything to do with it?
