82 crossfire NTK TPS
I know the TPS was working fine when installed so im wondering if the internal pot just can't handle the current passing through it. I changed it with an SMP sensor - will see if this one survives.
symptoms were: odd idle drop on decel (it liked when i was on-throttle, hated idle position), really badly rich coughs during idle drop. While rolling into throttle, the TPS was operating fine and the car would run up through the rev range OK. seems like the potentiometer range where the TPS was parked often (idle/off throttle) failed.
Hi Ahrmike,
Thanks for the info on tps brands.
I am fighting an issue with my 82 crossfire and was just wondering if any of your bad tps symptoms included what I will call bad performance when rolling in the throttle through low to mid exceleration? How about a popping / backfire sound that seems to come from the throttle body units ?
Last question.. Where you able to adjust both of those tps’s to the .525 volt output on the signal wire ?
Thank you for any thoughts..
Jon
I was able to adjust the badTPS to .525V BEFORE it went bad. Noting I had a LOT of movement in both directions. I didn't check afterward since I did a simple resistance check and realized there was a dead spot where it would spike to near infinite resistance. I would recommend checking your TPS with a simple resistance check as you rotate the sensor. I am thinking it may have been damaged when I initially installed since i let the sensor "flick" back to zero a few times too rapidly when i was first installing.
You should check the voltage at the TPS harness as well as the resistance to ground through the ground wire on the harness. Maybe you have a bad ground or bad ECM voltage supply?
HIGHLY recommend the ALDL cable too. relatively easy to use once installed and it gives "live" information from TPS to temps, etc. From your symptoms, you likely have a bad ecm or bad sensor somewhere so the ALDL cable would narrow that down significantly.
So both my original TPS and the new one cannot be adjusted to the .525 setting. They both run out of physical room for adjustment I move the sensor to the highest position and still can only .480 or something right around there. As you pointed out I did verify that the ground going to the TPS connector, seems good and my measurements didn't change when I put the meter on another solid ground. Also the input voltage to the tps is 5 volts.
I was always thinking mine was a lean pop. I think you are saying that your tps was reading low and you did have a lean condition. I think with my base tps setting at .480 then the computer would always be supplying less fuel and behind the throttle plate and air supply position. Does that sound right and possible to you?
I am going to try opening up the tps slot to allow me to get that base setting correct, even if its just a test to verify this theory.
Thanks, I'll look into that cable. I suppose you need a computer and some specific software to complete that function?
Thanks again, much appreciated!
Jon
Jon
ALDL cable requires the cable and a free software + windows laptop. Pretty simple to set up but it does take a little research into what to connect/where.
I was doing the TPS voltage tests by back probing the wires with the connector attached.. But you have a good point. If the wire from the TPS output is compromised back to the ECM the ECM could be receiving and acting on an incorrect reading. I will try to identify this wire and check it..
Will soon replace the Coolant temp sender and the MAP sensor. But not sure that they are bad just replacing to rule them out.
I don't see anything to indicate the alternator out put is off but I'll check it next time I'm able.
Thank you for the ALDL cable info. Any idea of what the software is called or where it might be available?
Thank you again and have a very Happy 4Th of July !!
I bought the ALDL cable from:
https://aldlcables.com/collections/aldl-obd1-cables
For the '82, we need the 12 pin ALDL cable.
The software is here:
https://winaldl.joby.se/
you should donate to the guy if you get it working - I made sure to send some his way as a thanks for getting this program working. His site has a lot of instructions on how to get things to work properly.
The stock 82 ECM number is: 1225550, which you need to select on the winALDL software during startup.
If you order it and need more help, let me know - i can walk you through it step by step.
I'd recomend doing the MAP anyway since its so easy to get to - if it changes nothing, keep the old MAP as a spare. If it improves it, toss the old MAP and buy another one as a spare. The coolant temp sender may help but just realize youre gonna bleed a little coolant. While doing the MAP sensor swap, I'd recommend changing out the vaccum line too since the old lines usually have invisible pin-holes and leak. Mine definitely was leaking.
In my car, I have a spare MAP, ICM, rotor, cap, longest plug wire, extra plug, TPS, fuel filter, and the tools to swap them. nearly all of them will take less than 30 minutes to change and its pretty easy to guess which one is going bad. I don't have a spare coolant sensor since i figure if it goes bad, itll run like crap but still run til i get home.
I had researched the cable and software but as you said there were a lot of choices. Thanks to your specific info I think I'm all set. Very wise to keep those spares. Even though it's said they don't go bad they are so accessible I'd say it's a reasonable troubleshooting step. I'll update as soon as I have those sensors swapped.
Take care,
Jon
Thanks again for your help..
Yes thanks. Made a fuel pressure gauge test rig for between the 2 throttle bodies and the fuel pressure is within the factory specs. Thanks again…
So if you're able to sweep it while its not installed and you can register the .525v (and higher), then its likely not seated properly when installed.
Yes - that could definitely cause big issues. the lever has to be moving when you depress the throttle pedal. an easy way to test is to have the dmm hooked up and either compress the cruise control bellows, or pul the lever between the two throttle bodies. if the lever is on the other side and the voltage does not change your car essentially thinks you are not depressing the throttle at all, and will run lean and spit and pop.
