LED tail lights
Old Jul 16, 2025 | 01:10 PM
Bikespace's Avatar
Bikespace
Originally Posted by JC Pilcher
Lights- stock turn signal bulbs. Rear has LED tail lights. Side markers went back to stock bulbs. Installed the turn signals grounded relay on both hazard and turn signal locations. Hazards work as well as the running lights and the brake lights. When I activate the turn signal switch I get nothing. Dash doesn’t light up and neither do the tail lights. Looks like the fuses are good but I’m going to replace all the fuses with new ones. I checked to see if I have power to the relay and I do.
So by "dash doesn't light up", you mean you don't see green arrows when using the turn signals? Do the gauges light up (headlights on) and function otherwise? High beam indicator? "BRAKE" indicator?
I didn't see it in this summary. Have you tried the reversing base on the turn signal flasher with the current configuration?
You shouldn't need to replace any fuses, but I'm otherwise at a lost to explain what is going on.
Old Jul 16, 2025 | 01:26 PM
JC Pilcher's Avatar
JC Pilcher
Yes all indicators on the dash work. Everything works on the car except the signals. I’ve tried reverse polarity and regular.
Old Jul 16, 2025 | 01:31 PM
Bikespace's Avatar
Bikespace
Are there any LEDs in the turn signal indicators? It shouldn't matter in 70, since the bulbs are directional (you can get it backwards in 78-82).
I'm assuming you didn't try swapping back to stock taillights because you needed to cut and splice the wiring harness. Any chance the problem is there? A photo or three might really help. I'm really at a loss to explain what is happening.
Perhaps check the steering column connector.
Old Jul 16, 2025 | 01:50 PM
JC Pilcher's Avatar
JC Pilcher
I’m at work at the moment so no photos. Yes I spliced into the harness and double checked the wiring on a schematic. I’m going to check the column harness I guess. It’s new as well. When I got the car the stock lights were shot.
Old Jul 16, 2025 | 01:58 PM
walleyfisher's Avatar
walleyfisher
On my '74,
1. I have all incandescent bulbs in the dash
2. LED headlights (octain)
3. LED side marker lights (both front and back)
4. LED taillights/ brake light bulbs with the built in resistor
5. LED back up lights
6. Incandescent license plate bulbs (just haven't changed them yet)
7. LED switchback bulbs in front turn signals (white driving lights / w Amber flash)
8. The electronic flasher with the ground wire for turn signals
9. The electronic flasher with the ground wire with reverse polarity base for the hazard lights
Everything works great
Old Jul 17, 2025 | 03:47 PM
60 SHARK's Avatar
60 SHARK
I've been through this with several older cars. One more check,,, apply brakes. If they illuminate, keep them on and apply a turn signal, (right or left) if the brake light stays on for the side you chose, you have issues in the column switch 😉...
Old Jul 18, 2025 | 07:40 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by Eliredandblack
On my FIERO I installed LEDs in the tail lights. To get them working, I just purchased resistor units from Superbright LEDs. The only downside was finding a place to install the resistors. I still could use LEDs in the front turn signal without problems, so I just left the incandescents in.
Yes I was going to mention some times you need a ballast load resistor (which BTW negates the efficiency of the leds altogether and makes the leds less appealing to me for vehicle lights because of it) I had to install these in my truck when converting to led lighting.
Old Jul 18, 2025 | 08:17 AM
Bikespace's Avatar
Bikespace
You only need the ballast resistor if you don't use the 3-wire LED flashers (which the OP is using). I don't know about your truck, but it should be a simple plug and play for a C3 (front side marker lights are less simple, but still don't require resistors).
If not the steering column connector, my next guess is the turn signal switch (but both sides? odd).
OP, a wire-piercing test probe, like the one linked, might help you trace power more easily in the wiring harness, to narrow down where the issue might be.
