Lower Steering Column Bushing
I recently found that the lower steering column bushing has popped out of place for one reason or another. I have a Borgeson box, so the steering column is already collapsed an appropriate amount. I have sprayed penetrant, loosed the upper column bots, the bolts at the firewall, and the rag joint. I can pretty freely move the shaft inside the column, but I cannot get the bearing to slide at all, let alone back into place.
I have unclipped the collar in this picture to give you a better view of how far the bearing has popped out.
Does anyone have any advice?
