Air always hot through vents
Old Jul 26, 2025 | 12:52 PM
cole1179's Avatar
cole1179
4th Gear
Default Air always hot through vents
I’m having some trouble figuring out this HVAC issue. I know that a lot of things on it don’t work, but all I want is for the air blowing through the vents to not be very hot.
I replaced the vacuum shut off valve with a manual one to ensure that the heater core is certainly not heating up. But the air getting blown through the vents is still hot.
But from here, I don’t know what to do. I imagine the air is getting pulled in from the engine bay somehow.
Any advice is appreciated. Thanks
Old Jul 26, 2025 | 06:18 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
You've turned off the hor water. That should work.
So, how is the rubber weatherstrip on the hood? Sealing to the front of the cowl area? Not Sealing and letting hot air into the wiper tray area? How are all the HVAC doors operating?
I'm not there to fix it. But that weather strip on the hood is a good place to start. Often old, hard and useless.
hot air coming in console area due to insulation collar missing at bellhousing area? Rubber boot on the clutch rod perished? The list goes on. Get to work.
Old Jul 26, 2025 | 07:03 PM
Dodosmike's Avatar
Dodosmike
Unplug the circulating fan
IIRC most years fans dont have an “off” just low
I unplugged my ‘78’s fifteen years ago and it helped tremendously
do you have manual vents by the floor kick panels? Foam gaskets are likely gone.
Old Jul 26, 2025 | 09:07 PM
Motorvation's Avatar
Motorvation
This I agree with. My ‘71 convertible was a cooker. The rubber seals on the doors were gone.
Steve O.
Old Jul 26, 2025 | 10:06 PM
Bikespace's Avatar
Bikespace
Did you use TWO manual valves? Did you then completely remove the heater hoses from the engine compartment (which is at 180 degrees, BTW), or at least insulate them?
Here's @interpon's excellent guide on how to mitigate the heat issue. Unless you add coolness via A/C, the best you can do is slow it down, but there is a lot of low-hanging fruit left in your car.
https://www.corvetteforum.com/forums...e-79-w-ac.html
Old Jul 27, 2025 | 11:22 AM
kansas123's Avatar
kansas123
I turn the selector to Vent and then turn the fan to Off. It helps mine.
Old Jul 28, 2025 | 05:42 AM
ukjohn's Avatar
ukjohn
I discovered a couple of issues when refurbishing the A/C on my 78, which would probably also affect your 79.
When I removed the evaporator, I could see the vent door that shuts off the air flow through the heater matrix (See photo below). I found that with the cable that controls this door adjusted as per spec, it did not actually close the door. I've adjusted it now so that it does completely close the door.
The other thing I found was that the evaporator box (through which the outside air passes) being close to the exhaust was getting very hot. Almost too hot to touch. I put some reflective sheet on this which made a big difference to the surface temperature of the box and my A/C now blows noticeably cooler.
Old Jul 28, 2025 | 11:00 PM
Dodosmike's Avatar
Dodosmike
Blue box, upper right, good example of the fan power plug I was referring to. No "off , only low. I didn't want or need to run AC, so I unplugged mine.
Old Jul 29, 2025 | 03:46 AM
4-vettes's Avatar
4-vettes
Great Plan!
Now you can't run the fan for vents or heater or even defroster. Cause you NEVER get caught in the rain.
And even if you feel you don't need AC. (I think your nuts).
You may at least wish to use the vents.
Old Aug 4, 2025 | 09:23 AM
Dodosmike's Avatar
Dodosmike
Originally Posted by 4-vettes
Great Plan!
if that’s aimed at me, it takes 4 seconds to plug it back in, but I never did, never had an issue.
Old Aug 4, 2025 | 10:54 AM
interpon's Avatar
interpon
this thread and @bmotojoe 's help can be off and functional..
honestly after doing heat mitigation. Especially the foam collar and other mods, i have it back on..
79 no outside floor vents.
https://www.corvetteforum.com/forums...f-control.html
To Air always hot through vents
