New Door Lock install question. 1979 Corvette
I was struggling with long needle-nosed pliers, large screwdriver, and a combination of both. The new retainer was thicker metal than the original part. The original is in good condition, and I don't have any reason not to use it. I ran out of time fiddling with it last night and will try again tonight. But first I will have to either fish out the TWO retainer clips I dropped to the inside of the door. Oops. If I can't fish it out (with a magnet), then I will have to take out the lower access panel to reach them.
I will try again this evening.
Passenger side, prior to fitting the retainer clip.
Also, on the driver side, the entire locking system is very stiff and does not want to move very well. I am guessing excessive corrosion and dried lubricants in the pivots, but also the power lock solenoid might also be keeping things from moving, as it is also not working.
