1980 L48 Engine Knock
Old Jul 31, 2025 | 09:04 PM
Uniquemicro's Avatar
Uniquemicro
Default 1980 L48 Engine Knock
So I had no knocks before. I just put in a comp 268H cam kit, new disty and have Doug's Headers installed. New timing chain, springs, lifters, pushrods, water pump...
Car pulls fine, starts fine, idles fine. Thanks Lars Grimsrud (carb work) and Lakeside Auto in Richmond (timing, suspension).
Now. I hear a noticeable knock (passenger side) only when in drive. Driving I hear it, in the driveway in drive with the brakes on I hear it. I don't hear it in neutral or in reverse (driving in reverse or with brake on).
Transmission was maybe a quart low on fluid, I filled it (maybe a bit too much, we will see).
Any input will be appreciated.
Ken
Popular Reply
Aug 1, 2025, 07:50 AM
Uniquemicro
With replies like that, you will find wife #5 in no time brother.
Old Jul 31, 2025 | 10:33 PM
Rebelyell's Avatar
Rebelyell
Seems you've increased power and torque with your mods; it should have.
Perhaps your automatic transmission's flexplate has cracked; it happens routinely to even unmodified motors.
Cracked flexplates often knock.
Source location of bad sounds are routinely difficult to pinpoint; has fooled many.
Old Aug 1, 2025 | 12:08 AM
Piersonpie's Avatar
Piersonpie
I would check your fuel pump/pushrod. I tested mine by removing both and running the car off the gas in the float bowls. Works for long enough to tell if that’s what your issue is.
You can also remove spark plug wires one at a time to see if the noise goes away, and which cylinder is making the noise.
Old Aug 1, 2025 | 07:20 AM
bonesbrakr's Avatar
bonesbrakr
Motor mount??
Old Aug 1, 2025 | 07:36 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Sounds like you have a automatic transmission. Why bother?
Old Aug 1, 2025 | 07:50 AM
Uniquemicro
Old Aug 1, 2025 | 08:09 AM
HeadsU.P.'s Avatar
HeadsU.P.
Uniquemicro,
Your symptoms all have one thing in common pretty much.
Engine under load. In gear, driving, brake applied, etc.
I would think this scenario points to the vacuum advance canister.
Your new cam changed the vacuum signal, given in inches.
You will need to figure out your:
Initial Timing w/ vac
Initial Timing w/o vac.
Mechanical advance added
And vacuum degrees added.
No more than 8 -12 degrees of vac is needed.
Testing can be done with a Mighty Vac + Timing light
Old Aug 1, 2025 | 08:10 AM
Golfobsessed's Avatar
Golfobsessed
getting old... got any new material
Old Aug 1, 2025 | 08:16 AM
Uniquemicro
Originally Posted by HeadsU.P.
Uniquemicro,
Interesting you mention that. The shop capped off my vacuum advance saying that it added way too much advanced under load and that the mechanical was enough to get to 36 degrees total advance.
How do I test this theory of yours?
Old Aug 1, 2025 | 08:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Oh-no. Not another mechanic that does not understand the importance of Vac Adv.
If you truly do have too much vac adv, there is a limiting plate that fits under the arm of the canister.
One screw holds it. Maybe $15. Have one myself, set to 10 degrees max.
But for now, you need the two tools I mentioned, then some basic knowledge of how to perform the test and get results for each setting above.
Old Aug 1, 2025 | 10:46 AM
Uniquemicro
Can you provide me more information? I have replaced the disty with a brand new Pertronix unit that has an adjustment screw inside the canister - is this what are are talking about? Any information will help.
Ken
Old Aug 1, 2025 | 11:52 AM
Piersonpie's Avatar
Piersonpie
Email Lars at V8fastcars@msn.com and ask for a copy of his timing and vacuum advance papers.
Old Aug 1, 2025 | 02:03 PM
Uniquemicro
Got it already. That is how I installed mydisty.
Old Aug 1, 2025 | 02:38 PM
sullyman56's Avatar
sullyman56
Disty?
Old Aug 1, 2025 | 05:05 PM
Piersonpie's Avatar
Piersonpie
In the papers it talks about how the vacuum advance works. Adding in more timing during times of light engine load, like cruising or idling.
Yes, 36 total degrees of mechanical advance is ideal when you’re accelerating, but when you’re not the engine can handle quite a bit more. With modern gasoline that number is 12, giving you a total of 48 degrees when the mechanical advance is fully engaged. This much advance during light load wont hurt the engine in any way.
If the shop set your total mechanical advance to 36 your initial will probably be somewhere in the mid teens. I would measure your timing at idle with the VA unplugged, add 12 to that number, then hook up your VA to a manifold vacuum source and adjust until you’re getting that number. With the VA in combination with your aftermarket cam the engine will run better at idle, run cooler, have better throttle response, and get better fuel economy. It might solve your knocking problem too.
Old Aug 1, 2025 | 08:08 PM
HeadsU.P.'s Avatar
HeadsU.P.
Unique,
Yes, some Vac Adv canisters have an allen screw inside the hose port.
That allows you to tweak the timing for more vacuum or less vacuum advance.
What that adjuster screw does not do is, limit the maximum allowed.
So, there is where your tools of the trade will help you diagnose. Timing Light, vacuum gauge or better yet, Mighty Vac pump.
Also. At the other end of the Vac canister hose:
Where are you getting a vacuum source?
You have to find "your" current timing numbers before you put a hole in a piston.
Old Aug 1, 2025 | 08:15 PM
HeadsU.P.'s Avatar
HeadsU.P.
Initial + Mechanical = total (34-38*) timing, no vac.
Plus 10* - 12* vac gives you 48* - 50* cruising.
But, anyway, I think the O.P. vac adv is too high, sticking or perhaps hooked up to a bad supply source.
That's why his mechanic chose the "cap-it" repair. "There. All fixed!"
Old Aug 1, 2025 | 08:25 PM
Piersonpie's Avatar
Piersonpie
Piersonpie,
Reread your post.
That's why his mechanic chose the "cap-it". "There. All fixed!"
That is what I mean. Not too great at the whole writing thing, but I hope I get the point across that vacuum advance is good to have on a street engine.
BTW some of the adjustable vacuum advance canisters to allow you to change the amount of advance as well as the vacuum level you get said advance at. They’re adjusted by the same screw though, so you’re set to a certain vacuum level to get 12 degrees. A canister that allows you to adjust these variables independently would be ideal, but I haven’t been able to find one for an HEI.
Old Aug 3, 2025 | 02:18 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
A properly adjusted vacuum advance is essential on street driven cars.
These engines are mostly driven at part throttle, and that is where it works.
Deleting it is an old-school race car mod that has persisted for some 50 years, and has no business being done on any street driven car.
Believe it or not, even an L88 drives better at part throttle with vacuum advance hooked up, if it is tuned properly.
The factory tuned them for race only, and did not care about the street, and deleted it.
Just like the fan shroud, radio, heater, defroster, etc.
But stock vacuum advance cans do not work well with modified engines, you have to know how to tune them.....
That adjustable vac can, and a 10* limiter, and Lars papers, are all you need.
To 1980 L48 Engine Knock
