Headlight Switch
Old Aug 1, 2025 | 06:45 PM
Bvlams's Avatar
Bvlams
Default Headlight Switch
I installed a new headlight switch (zip corvette). When i connect the battery, the courtesy lights stay on regardless of the switch position. Is there some sort of delay when they turn off? Not sure what else it could be ? Its a 1979 and i made sure the position switch is off.
Old Aug 1, 2025 | 06:59 PM
interpon's Avatar
interpon
you may want to put in more details..
year, options if inown, etc
twist **** to make sure not on on position
Old Aug 1, 2025 | 08:04 PM
17Mc's Avatar
17Mc
Check the door jamb switches they might be stuck or grounded. Also, verify the headlight switch isn’t pushed in (activates dome light). If those are good, trace the courtesy light wire for a short to ground. No delay they should turn off immediately.
Old Aug 1, 2025 | 08:17 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
77 and newer do have a delay feature. But should turn off in 30 seconds give or take with both doors closed.
Old Aug 2, 2025 | 08:13 AM
JavaJolt78's Avatar
JavaJolt78
Tx for that info 4-vettes bc I have had my 78 for quite awhile and never knew that??
Probably bc I very rarely drive at night!!!
JJ78
Old Aug 2, 2025 | 10:42 PM
4-vettes's Avatar
4-vettes
Well, truthfully, at least in 77 the delay is part of the convenience group option. So, technically, not all of the car's have this option. Sorta like the underhood light.
To Headlight Switch
