Battery Size
It's about as large as you could fit.
There does seem to be a bit more room lengthwise available but I reckon this oughta be good enough.
I have this same size in my Murano so I pulled it out of the Murano and put it in my 68..... well, that's after I was at Costco and figured it was worth the effort to go back home and try it.
Last battery I had was (I think 550 CCA) and it worked fine..... wouldn't die....lasted me over a decade
I will definitely check into that Costco battery.
When I purchased my battery cables and connectors I purchased the Marine type that connect to the top posts and have threaded studs so I can connect additional electrical connections directly to the battery.
I also plan to install positive and ground terminals to tie anything else to.
I much prefer side post for safety, and fleet compatibility. I use them with Anderson connectors for trailer winches, too.
