Slight bog off idle
Old Aug 26, 2025 | 01:40 AM
Z51JEFF's Avatar
Z51JEFF
Default Slight bog off idle
I've got an 81 4-speed and at times it seems to bog down slightly when taking off in first gear. The carburetors been rebuilt and TPS adjusted to correct voltage. I've tried adjusting the air/fuel mixture using a dwell meter but can't get a correct reading. Currently air/fuel mixture screws are at 3 turns out. At one point I completely isolated all vacuum ports coming off the carburetor. Any tips would be greatly appreciated.
Old Aug 26, 2025 | 10:59 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Any engine or drivetrain mods?
Or 100% stock?
Stock # QJet?
Old Aug 26, 2025 | 06:08 PM
Z51JEFF's Avatar
Z51JEFF
Or 100% stock?
Stock # QJet?
Stock no mods
Old Aug 27, 2025 | 04:53 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
100 percent stock electronic carburetor.
Did these actually ever run perfectly?
Sorry.
If it were mine it would quickly become not 100 percent stock.
Have you tried using a AFR Meter to judge rich or lean?
Considered using a 80 and earlier carburetor or aftermarket carburetor? Or even changing over to EFI?
Old Aug 27, 2025 | 05:55 AM
Z51JEFF's Avatar
Z51JEFF
Sorry.
For the time being must be 100% stock. I'm going to check out a few possibilities there is an issue with the carburetor even though it was rebuilt by a -reputable- shop.
Old Aug 27, 2025 | 09:19 AM
pltmgr's Avatar
pltmgr
Accelerator pump?
Old Aug 27, 2025 | 10:08 AM
Z51JEFF's Avatar
Z51JEFF
Originally Posted by pltmgr
Accelerator pump?
One of the parts that will be replaced
Old Aug 27, 2025 | 10:49 AM
olescarb's Avatar
olescarb
have you tried disconnecting the hose to the egr valve to see if that helps? what is the dwell at idle and 2500 rpm?
Old Aug 27, 2025 | 10:52 AM
Z51JEFF's Avatar
Z51JEFF
I can't get an accurate reading, I'm considering replacing the EGR valve.
Old Aug 27, 2025 | 11:10 AM
MelWff's Avatar
MelWff
The 3 turns out is what you ended up with after adjusting the two screws for best idle in gear if an automatic?
Old Aug 27, 2025 | 11:43 AM
olescarb's Avatar
olescarb
just try disconnecting the hose from the egr first before you buy a new one. what are the dwell readings you see?
Old Aug 27, 2025 | 04:16 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Listen to this guy!
Maybe the best carb expert around.
Old Aug 28, 2025 | 02:55 AM
Z51JEFF's Avatar
Z51JEFF
I can't get an accurate dwell reading,it's jumping all over the place. I've been told I need to replace the O rings on the AIR/BLEED valve,there's a vacuum leak somewhere and there's a good possibility it might be coming from here. When bringing the RPMs up the dwell meter moves up with the revs. It's my understanding that when the carburetor was rebuilt the O rings for the AIR/BLEED valve should have been replaced but they weren't. No too happy with the shop that rebuilt the carb.
Old Aug 28, 2025 | 10:41 AM
olescarb's Avatar
olescarb
the dwell reading should read in the 5 degree range if it is running to lean because the computer is commanding a richer mixture, a dwell reading in the 45 degree range is commanding a leaner a/f mixture. If you disconnect the m/c solenoid the carb will go full rich, be sure the air pump is not pumping up stream into the exhaust manifold (pinch the air pump hoses closed)) it would cause the o2 sensor to see the extra air as a lean condition. i have never seen a dwell reading that jumps all over the place.
Old Aug 28, 2025 | 11:01 AM
Z51JEFF's Avatar
Z51JEFF
The setting is for 30 but I cant get it near that. And when you hit the throttle the needle moves like a tach,sweeps to the right. I checked another 81 out of curiosity and it was pretty close to 30 and stable as it should be some what so there's something goin on here. I'll look into it when I get the parts. I really pissed me off that a carburetor that I've spent so much on already,isn't right. I'll find it at some point.
Old Aug 30, 2025 | 04:08 AM
Z51JEFF's Avatar
Z51JEFF
@olescarb I didn't make to connection until now. You've done some work on a Holley I had years ago,NOVA JOE recommended your shop. I wish I would have remembered your shop when I had this Rochester rebuilt. I'm waiting on some parts,I haven't done anything with the car for a few days but will look into the EGR valve before and replace the O rings on the AIR/BLEED valve before I take it apart. If it does need some work I'll most likely bring it by. Thanks for the info,greatly appreciated.
Old Sep 1, 2025 | 12:13 PM
Z51JEFF's Avatar
Z51JEFF
I may have found the issue. I removed the idle air bleed valve to get a look at the O rings and one of them was completely worn. I used some silicone on the O ring to get it to seal and the car runs better with a smoother idle. I've ordered a rebuild kit with the O rings. Thanks for the tips/info,greatly appreciated.
To Slight bog off idle
