Hey there all C3'ers and of course the title says it all almost!!
I found a L-shaped L what looks like a shiny bracket and in the middle was a screw on the passenger side of the QJet below the fuel inlet that was next to a vacuum line that routes to the dizzy...
Can anyone tell me what the screw is and what is it used for???
I tried to take a pic but could not get close enough to get it framed
JJ78
Is this the same 17056206 from your previous thread? A picture that shows the general area would be helpful. My first thought would be the fast idle adjustment screw.
Originally Posted by drwet
You don't need to experiment. Set it on fast idle and adjust it to spec.
Originally Posted by JavaJolt78
OK I'm thinking about 1/2 turn to start and go from there?
JJ78
Mike -
Just start the car up cold and turn the screw to the desired fast idle rpm. I set it to 1270 rpm when I set the carb up for you. Instructions for this were included in the installation instructions with your carb.
Lars
