3000 RPM Backfire?
Old Feb 16, 2003 | 08:59 PM
1971Ultra's Avatar
1971Ultra
Default 3000 RPM Backfire?
Here's one for the Forum.
Just installed the ZZ4 Fastburn. I have about 300 miles on the motor.
The car runs great at 55mph/2500rpm in 4th gear. As soon as I take it to about 60/65mph and just about 3000 rpm's, the engine backfires bigtime, plus a few other noises that I can't convey (really scary). Once I get past the 3000 rpm barrier it seems to be OK.
Furthermore, I noticed that it does the same thing in 1st, 2nd and 3rd gear at right around 3000 rpm.
Too rich? Too lean? Electrical? Any ideas?
Kipp
[Modified by 1971Ultra, 1:59 AM 2/17/2003]
[Modified by 1971Ultra, 2:00 AM 2/17/2003]
Old Feb 16, 2003 | 09:13 PM
The Money Pit's Avatar
The Money Pit
Default Re: 3000 RPM Backfire? (1971Ultra)
If I were to guess I'd start by checking the distributer and spark plug wires.Crossfire maybe,or a dead spot in the ignition module.
Old Feb 16, 2003 | 09:19 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I think it is too lean, it could be from fuel starvation. Perhaps your pump is failing or the one of your fuel filters is partly plugged. I guess it could be a timing issue of some kind.
Old Feb 16, 2003 | 09:37 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
I am having almost the exact same problem. I hope we both find our problem, because if you are like me, it will drive you crazy. Mine for the most part is a pop/miss, but last week it did backfire in the exhaust which is really odd. I have changed everything except the plug wires. I am thinking it is not fuel related but who knows. Keep us posted.
BTW the wires I have now are 1 yr old TAYLOR wires, from what I have seen so far I will never buy Taylor wires again.
Old Feb 16, 2003 | 09:42 PM
Alwyn678's Avatar
Alwyn678
Default Re: 3000 RPM Backfire? (The Money Pit)
:withstupid:
Old Feb 17, 2003 | 01:09 AM
1971Ultra's Avatar
1971Ultra
Default Re: 3000 RPM Backfire? (Alwyn678)
By checking the distributer, what should I be looking for? Points? Timing? :confused:
Do you think maybe the ignition box (MSD 6A) may be bad?
The sparkplugs wires are brand new (MSD)
Old Feb 17, 2003 | 01:26 AM
Denmech's Avatar
Denmech
Backfire out the intake or exhaust?
[Modified by Denmech, 6:27 AM 2/17/2003]
Old Feb 17, 2003 | 01:37 AM
1971Ultra's Avatar
1971Ultra
Default Re: 3000 RPM Backfire? (Denmech)
There is much popping coming from under the hood. And to be honest it sounds like backfire is coming from both locations. I am going to have to pay a little more attention.
Old Feb 17, 2003 | 01:57 AM
Turbo-Jet's Avatar
Turbo-Jet
Afterfire (thru exhaust) under acceleration is usually caused by lean a/f ratio, or timing, assuming valvetrain mechanics are functioning normally. Afterfire on deceleration is usually caused by rich idle or part throttle a/f ratio, our leaking fuel nozzles due to high vacuum signal, or too high of a float height.
Backfire (thru intake) is almost always a result of timing errors, either over advanced or inconsistency in spark voltage or distribution.
Have you pulled your ALL the plugs? How do they look?
I’m no expert, but it sounds as if your MSD brain is whacked.
:skep:
Old Feb 17, 2003 | 05:10 AM
lou's Avatar
lou
Is this a new or old distributor?
Old Feb 17, 2003 | 01:48 PM
1971Ultra's Avatar
1971Ultra
Default Re: 3000 RPM Backfire? (lou)
Not sure on the age of the distributer. The MSD came with the car when I bought it and the previous owner had not record of its purchase. Same goes for the MSD6A ignition box.
If I replace the box is there any preference for the 6A or 6AL. As far as I know the only difference (other than price) is that 6AL has rev limiting capabilities.
As for the the plugs, they are also brand new. I will check them all again.
And as always, the Forum is full individuals willing to share information, experiences and ideas. THANKS
Old Feb 17, 2003 | 02:10 PM
LAvetteman's Avatar
LAvetteman
I sent my box to MSD and they gave it the ALL OK. But, who to say thats not where my problem is.......
Old Feb 17, 2003 | 04:07 PM
Bearcat's Avatar
Bearcat
Default Re: 3000 RPM Backfire? (71,454,4spd)
Sounds to me an awful lot like busted valve springs. Pull the valve covers for a quick look-see.
Old Feb 17, 2003 | 10:42 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: 3000 RPM Backfire? (Bearcat)
This has happened to me. I went through 2 sets of pistons before i figured it out. The carb is jetted too lean. Its lean backfire thru the carb. Are you using your stock Q-Jet? If so, it would need bigger jets to accomodate the much higher breathing capacity of your new hi-po engine. You should take care of this ASAP before you burn a piston.
jim
Old Feb 18, 2003 | 06:54 AM
Denmech's Avatar
Denmech
Default Re: 3000 RPM Backfire? (turtlevette)
:iagree: I would check this first! If dist is old I would check for play in the shaft.
Old Feb 18, 2003 | 01:20 PM
1971Ultra's Avatar
1971Ultra
WOW - the last thing I want, is to go through psitons on a brand new motor.
The carb is also brand new - Speed Demon 750. I will address a potential lean issue and go from there.
Old Feb 18, 2003 | 02:13 PM
turtlevette
You wouldn't think that a high performance carb would run lean unless it was purposely jetted that way on your old engine. I would also check your fuel pressure as a previous poster suggested.
How does the engine pull under heavy acceleration?
jim
To 3000 RPM Backfire?
Old Feb 19, 2003 | 03:44 PM
KNEVER's Avatar
KNEVER
I would try another carb just to see if the problems go away. I had a new speed demon doing the same thing. check out lars's post about BG tuning.
Old Feb 19, 2003 | 03:52 PM
LAvetteman's Avatar
LAvetteman
Default Re: 3000 RPM Backfire? (KNEVER)
My vette started doing it with my old holley (750) and continues to do it with my new speed demon(850). Makes you want to rule out a carb problem.
Old Feb 19, 2003 | 03:54 PM
Fevre's Avatar
Fevre
Default Re: 3000 RPM Backfire? (Turbo-Jet)
:skep:
:yesnod:
When I changed cams and tried jetting with a O2 sensor I was reading it wrong and kept jetting it up thinking it was running lean. :bb Car backfired when dec and shoot flames. :eek: Once I figured out i was an idiot and started reading the O2 sensor right, I leaned out all four jets and have not had a problem with backfire since.
