82 Strut Rods
Old Sep 11, 2025 | 05:57 PM
jthornton's Avatar
jthornton
Default 82 Strut Rods
The Factory Assembly Manual states install the strut with the outboard end toward the front. Are both ends symmetrical so all you have to do is install it in the strut carrier with the outboard end toward the front?
JT
Old Sep 11, 2025 | 09:19 PM
DaveL82's Avatar
DaveL82
The 80 to 82 cars have an aluminum diff which is located further back. The strut rod ends are not at 90 degrees as we're earlier cars, they are at an angle.
Old Sep 12, 2025 | 07:51 AM
jthornton's Avatar
jthornton
So my question was are both ends at the same angle?
JT
Old Sep 12, 2025 | 05:17 PM
DaveL82's Avatar
DaveL82
To be honest Im not sure. I went to strut rods with heim joints a long time ago but I do think the angle is the same. Place them on the ground with a long bolt through both ends to see if they are parallel.
I think the bushings at the diff end have a smaller bolt vs. the shock mount bolt diameter.
Old Sep 13, 2025 | 12:03 PM
jthornton's Avatar
jthornton
Originally Posted by DaveL82
To be honest I'm not sure. I went to strut rods with heim joints a long time ago but I do think the angle is the same. Place them on the ground with a long bolt through both ends to see if they are parallel.
The bushings on my 82 are the same size for both inner and outer.
JT
Old Sep 13, 2025 | 02:22 PM
Fly skids up!'s Avatar
Fly skids up!
JT
Yes
To 82 Strut Rods
