Stumped big time
Old Sep 21, 2025 | 06:47 PM
bmotojoe's Avatar
bmotojoe
Originally Posted by Kdavis2271
it definitely moves freely and doesn't feel like it's stuck when I move that little lever.But that little arm isn't attached to the lever, and it won't stay attached
Because you're thermostat housing has pipe plugs in it the original EFE TVS switch has been removed. (TVS = Thermo Vacuum Switch). Plug that hose with a golf tee. If you have the original air cleaner the switch posted above is where that loose hose attaches to. The other port of that switch a vacuum hose runs to the air cleaner front air intake actuator.
