MSD box, tips for wiring?
Seems You also have MSD ULTRA 6AL P/N 6423 CD Ignition Box.
here is MSD link to MSD instructions for MSD ULTRA 6AL (pretty sure that's a "digital" box, Not "analog").
https://documents.holley.com/6639ebb...a3805561c9.pdf
An ICM is essentially an amplifier; and likewise, a CD box is also an amplifier.
Suggest: Do Not Remove the OE 4-pin ICM (Ignition Control Module) inside OE HEI distributor.
Instead, Solely disconnect the ICM, but wire "around" it; in order to connect MSD box.
Why? because MSD CD boxes can and do fail; especially digital versions. An Inconvenient Truth: When any CD box fails, it's unlikely there's anyone nearby who can affect genuine repairs.
BUT, If the ICM is in place, and you have wired system so that it can be readily reconnected, you can simply reconnect ICM; effectively bypassing a failing CD box.
