Need some ideas
Old Sep 27, 2025 | 02:29 PM
Kevin LD's Avatar
Kevin LD
Default Need some ideas
History....i have had the steering column apart and back together. I have had the entire dash out all to do other things and found the short in the steering column. It was the three wire combo left and right turn and cruse was pinched and shorted. Found the short and putting things back together. I hooked up the spedo and tach connection just to make sure all my new led lights were working properly. Hooked up the battery which is charged and turned on the key to start the engine and nothing....No engine fire and no dash lights. I tried the radio and that works fine. My next thing is to check all fuses to see if they are good and get power thru them. What else should I check?
Old Sep 27, 2025 | 02:50 PM
kanvasman's Avatar
kanvasman
There are fusible links going to the starter harness. You probably should get a wiring schematic for whatever year your car is. That will help you set up a map of what/where to look for your problem rather than just guessing. Good luck.
Old Sep 27, 2025 | 03:11 PM
Kevin LD's Avatar
Kevin LD
Thanks, I actually do have a good schematic but as far as I can tell it does not show any fusible links....or am I missing something?
Old Sep 27, 2025 | 04:01 PM
Tampa Jerry's Avatar
Tampa Jerry
You have to be missing something. GM added fusible links to Corvettes in 1967. For added safety, I added a few to my 66. Jerry
Old Sep 27, 2025 | 04:47 PM
Kevin LD's Avatar
Kevin LD
I just didn't know what to look for. Now I can seem on the schematic. Next problem, I replaced the hood latch from drivers' side to passengers' side and it's been working fine. But of course, now that I need to get to the starter fusible link, I can't get the passenger side to open. Today is just not a good day for working on the vet. Seems like everything I touch causes another problem. Anyone know how to get the hood to open?
Old Sep 27, 2025 | 05:07 PM
Kevin LD's Avatar
Kevin LD
Just googled it and I'm going to try getting to the latch thru the hole in the firewall. I'll let you know if I have success
Old Sep 28, 2025 | 02:37 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
clutch safety switch or the park/nuetral saefty switch?
Old Sep 28, 2025 | 06:42 PM
Kevin LD's Avatar
Kevin LD
Now I feel really stupid. I moved the shift lever back when I took the dash out and it was in drive. Problem solved thanks to Rescue Rogers!!! However, I did take the starter out and replaced the fusible links before I saw Rescue Rogers post, serves me right for overlooking the shifter not being in park. Now I can resume the assembly and get things done.
To Need some ideas
