1974 C3 Power Steering Control Valve
Old Sep 28, 2025 | 02:13 PM
captng1's Avatar
captng1
Default 1974 C3 Power Steering Control Valve
Hello All,
Take a look at the attached video of my power steering control valve. Is there supposed to be this much movement on the stud attached to the pitman arm? Seems to be a lot?
Old Sep 28, 2025 | 02:17 PM
captng1's Avatar
captng1
Sorry guys,
The system won't let me upload an mp4 video clip. Trying to figure out how top post...
Old Sep 28, 2025 | 02:27 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
YEs there is a lot of movement if the engine is not running....heres a video I did a while back
Old Sep 28, 2025 | 02:30 PM
captng1's Avatar
captng1
Thanks Rescue Rogers. I am talking about the whole control valve moving side to side. Trying to upload a video here, but can't figure out how to do it? It won't take an MP$ file format. Any suggestions?
Old Sep 28, 2025 | 03:08 PM
captng1's Avatar
captng1
Hello All,
here is a link to the video on you tube. Let me know what you think...
Old Sep 28, 2025 | 03:10 PM
Rescue Rogers
Check the settings on youtube...
but if the whole thing is moving, the threads on the end might be stripped.
Old Sep 28, 2025 | 03:13 PM
Rescue Rogers
It threads onto the center link then is clamped down
Old Sep 28, 2025 | 03:19 PM
captng1's Avatar
captng1
If you look closely in the video, you can see that the movement is at the bottom of the ball stud that attaches to the pittman arm. There is a rubber bushing that sits at the bottom of the stud that appears to be wiped out. I believe it dissolved over years from a power steering fluid leak. Just not sure how much play that stud is supposed to have in it?
Old Sep 28, 2025 | 05:04 PM
Rescue Rogers
I dont think thats normal. I dont think I have much movement in mine at all...let me go look
Old Sep 28, 2025 | 05:11 PM
Rescue Rogers
mines solid, doesnt rotate at all....yours is jacked!!!
Old Sep 28, 2025 | 05:12 PM
Rescue Rogers
There is a through bolt that keeps it from rotating like yours, is it tight, its in that diagram I posted
Old Sep 28, 2025 | 10:39 PM
captng1's Avatar
captng1
Thanks Rescue Rogers,
I will check to see how tight the bolt is...
To 1974 C3 Power Steering Control Valve
