Possible DUI distributor issues
Last week I installed a DUI distributor and took the car for a test drive. 10 or 20 minutes in, the control module failed. I spoke with DUI and they told me that based on the ID number, the distributor was build during a brief time that they had an order of modules that were overheating. They sent me a new module and I installed it with heat seek cream. I did a short test drive and it ran great.
Today I drove the car to work and it ran fantastic, until about 15 miles in when I gave it about 3 seconds of WOT. It ran great under WOT, but after that when I accelerate it stumbles bad. I put it in neutral and it revs perfect with no stumble. Back under load, it stumbled. I have to feather it to get the RPMs up enough to drive without stumbling.
I made it to my office and am hoping once it cools that it runs better to get home. I suspect the control module is going bad again. I know my fuel system is good and I don't think it is a coincidence that I'm having this issue (that I have never had) until I put this distributor in.
What are you thoughts? I know I'll sit here a my office all day running ideas through my head of what the issue could be, so I thought I would ask you guys to ease my mind until I can start troubleshooting. I've emailed DUI already. I may just pull this distributor and send it back at this point.
Keith
Maybe the coil is damaged now, I don't know. It is odd to me that it was running great until I got the rpms up really high on WOT. That 3 seconds shouldn't have increased the heat at the module to damage it. So strange.
When I installed this distributor, I gapped my plugs to .55, as suggested by the manufacturer. That is the only setup difference between this distributor and the one I replaced.
Keith
The DUI won't perform "better" than a cheap HEI. It simply comes set up with the "correct" advance, and was (I thought) higher quality than anything else. Spark is spark, at least at street RPMs.
Can you switch back to the cheap HEI, and see if you have issues? I'm guessing coil at this point, but retarded timing will make your engine run hot. More heat in an already crowded C3 engine compartment could help cook some marginal parts.
I have no idea how heat proof they are, but I'd look into this distributor instead. Perhaps DUI will accept a return after all of the problems you've had.
https://progressionignition.com/
I just went out at lunch to see if it ran differently now that the engine is much cooler. I wouldn't idle and loped like I had a huge cam in it before it eventually died and won't start. Acting the same as it did with I didn't have spark, so assuming the control module or coil went out.
Good thing it is at my office and not on the side of the road. Bad thing is I don't have a ride home now.
Post some photos if you can, perhaps someone will spot something obvious that you can fix easily. Could the distributor clamp have slipped?
Keith
Keith
There's no free lunch in life. When you open up the gap, you automatically shorten the arc time (and stress the module). There's certainly a possibility that the coil is defective, but I would reduce the plug gap back to .035" first before running the new module.
Thank you,
Keith
Keith
Larger gaps require more voltage to arc over, and from the equation above, something has to give, and that's the arc duration. Additional system energy from the coil restores the desired arc duration.
The reason the system isn't a labeled a high voltage ignition (an HVI, as it were), is due to the lower compression ratios in the engines of that time that didn't need high voltage to arc the gap. A genuine HEI unit will usually work well in older higher compression engines, but the larger plug gap usage isn't necessary in older engines (due to the richer mixture fueling and the higher compression forcing a greater percentage of the mixture into the plug gap) and isn't preferable for long term durability of the module.
The basic physics is the same for your DUI setup, but I don't know the electrical specifics of that system. Unless you're running low compression and lean mixtures I'd stay at .035" gaps. Plugs will last forever at the setting, and the module power transistor will thank you.
I'll get the gaps back down to .35 as soon as I can get it safely back home. In the meantime, it looks like an Uber ride is in my future today.
Keith
The newer HEI systems prefer a .45 gap.
Not sure where you came up with super wide 55?
The goop that goes under the modge is not really an insulator for heat.
It actually withdraws (sinks) heat away from the modge and disperses it to the distributor body.
That's why it's called Heat-Sink-Compound.
Never use dielectric grease or other substituits.
Under the coils dust cover, note a black GRD wire on one corner of the coils frame.
Make sure you have a bare metal connection there without any paint.
Under the coil is a Spring Bushing and rubber washer. (That is also seen protruding dead center under the dist cap)
DUI may have installed a High Resistance Bushing. Other dizzy have those as well.
The high resistance bushing adds heat in the cap. You may want to purchase a Low Resistance Bushing, around $19.
