Brake fluid moisture testers
Old Oct 1, 2025 | 05:14 AM
cottoneg's Avatar
cottoneg
Default Brake fluid moisture testers
Any recommendations on makes and models? I saw one on Amazon. But Amazon is falling out of favor with me as I have gotten fakes.
Having worked in a medical lab, we calibrated everything. Any way to know if the tester you buy works and is accurate? I read there are paper testers too.
Right now, I just flush the fluid every three years or before a track event.
Old Oct 1, 2025 | 02:57 PM
ctmccloskey's Avatar
ctmccloskey
There is a post that is current as of 10/1/2025 that mentions the same thing and shows a tester being used on Brake fluid.
Old Oct 1, 2025 | 10:07 PM
l8279vette's Avatar
l8279vette
We bleed the brakes before every event
Old Oct 2, 2025 | 07:14 AM
cottoneg's Avatar
cottoneg
I do too. But there are other cars that I do not track that I would like to test too. Like the Tundra I use to tow the car to the track.
Old Oct 7, 2025 | 07:36 AM
3X2's Avatar
3X2
I use a allosun em2272a tester.
Old Oct 7, 2025 | 09:33 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
It is really just a simple conductivity tester. Kind of foolproof even in cheap form.
A regular ohmmeter could be used to measure resistance, and go from there.
3% water is plenty.
I have seen technical papers that recommend a fluid change at 2 years.
File Type: pdf
To Brake fluid moisture testers
