Power Steering Control Valve Removal
Old Oct 2, 2025 | 04:43 PM
captng1's Avatar
captng1
Default Power Steering Control Valve Removal
Hello All,
I am trying to remove my power steering control valve. All the lines are disconnected, and the castle nut and cotter pin have been removed. I have a pickle fork between the Pittman arm but can't get a big enough swing on it with a hammer to break it free. (not enough room) Does anyone see a reason why I can't put a little heat on the Pittman arm where it goes around the ball stud to assist with breaking it free?
Old Oct 2, 2025 | 07:40 PM
interpon's Avatar
interpon
Maybe a cheap air hammer with a fork like that or I think Harbor freight sells or the automotive store sell a pretty good remover that you screw down and it pops off. Inspect everything close maybe it’s time to replace some parts to while you’re there
https://www.harborfreight.com/tie-ro...xoCbioQAvD_BwE
Old Oct 2, 2025 | 09:18 PM
stingr69's Avatar
stingr69
This is what you need.
Put a little pressure on the top of the stud by tightening the screw and a few taps on top of the lever and it will pop out.
Old Oct 2, 2025 | 09:59 PM
captng1's Avatar
captng1
Thanks Interpon,
That harbor freight tool may work. Not sure I have enough room to get it in there, but will check it out...
Old Oct 2, 2025 | 10:02 PM
captng1's Avatar
captng1
Thanks Stingr69,
I'm not sure I have enough room to get that in there? Its pretty tight, but I will check it out..
Old Oct 2, 2025 | 10:39 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
If you have an air hammer, hold it against the side of the pitman arm. Vibration and side-load will help release it.
Old Oct 2, 2025 | 11:19 PM
Bikespace's Avatar
Bikespace
In a real pinch, you could remove the pitman arm from the steering box.
It's one of the steps to installing a Borgeson power steering solution anyway.
You will likely need to buy tools for this solution.
Old Oct 3, 2025 | 06:44 AM
stingr69's Avatar
stingr69
Originally Posted by captng1
Thanks Stingr69,
That tool is what I used when I took my power stering control valve off for an overhaul. Came from Harbour Freight as well. It's pretty compact.
Old Oct 3, 2025 | 07:18 AM
jthornton's Avatar
jthornton
That's the tool I used and it works great!
Edit: and I see you properly greased the threads before using it.
JT
Old Oct 3, 2025 | 07:40 AM
cottoneg's Avatar
cottoneg
JT
I must agree with all of you. I was getting very frustrated and could not get it to separate. I was trying to get the pickle fork in there and it was driving me crazy. I went to Harbor freight, purchased stingr69 and others recommended. Off in 5 minutes. It’s worth the cost.
Old Oct 3, 2025 | 09:08 AM
captng1's Avatar
captng1
Thanks Barkingrats
Old Oct 3, 2025 | 09:09 AM
captng1's Avatar
captng1
Thanks Bikespace
Old Oct 3, 2025 | 09:10 AM
captng1's Avatar
captng1
Thanks Stingr69. I will go and get one..
Old Oct 3, 2025 | 09:12 AM
captng1's Avatar
captng1
Cottoneg, Gonna go get one..
Old Oct 3, 2025 | 01:27 PM
Tampa Jerry's Avatar
Tampa Jerry
Try your local Auto Zone, Advance Auto etc. Most will rent the tool to you for free. Jerry
Old Oct 3, 2025 | 02:09 PM
captng1's Avatar
captng1
Thanks Jerry
To Power Steering Control Valve Removal
