instrument cluster lighting?
Old Oct 16, 2025 | 04:44 AM
tlwjkw's Avatar
tlwjkw
Default instrument cluster lighting?
there was 0 lighting on tha instruments when i bought this car so replacing all with 194 leds.. discovered tha lamps in it were all good and lighting up when called for.. still no lighting showing up on gauges???. so cleaned tha whole package up and install all red leds.. they all come on ok but still no lighting on gauges??? have checked everything with how its assembled and can find nothing wrong?.. it can only go together one way that i can see because of tha clock stem.. what tha hell am i doin' wrong.. gettin' kinda frustrated...............
after some experimentation making tha room completely dark there is justa tiny bit of red light showing on tha gauges.. white is a complete no show... this is with 12v direct to tha circuit?
Old Oct 16, 2025 | 11:20 AM
Alan 71's Avatar
Alan 71
Hello,
It might help if you indicated what the car is.
The headlight switch also controls the dash lights... you turn the **** to brighten them.
Have you tried that?
Regards.....
Old Oct 16, 2025 | 12:06 PM
tlwjkw's Avatar
tlwjkw
i've got tha cluster in tha house and usin' direct 12v to 'em.. i think there may be several different lumans (?) brightness in tha 194 configurations.. these are supposed ta be direct replacement 194's?...
Old Oct 16, 2025 | 02:06 PM
tlwjkw's Avatar
tlwjkw
think it may be tha "printed plastic" circuit thingy?.. have two of tha five that are a lot brighter than tha other three..
Old Oct 16, 2025 | 02:37 PM
ZIOGEO's Avatar
ZIOGEO
you will get better help if you indicate what year the car is and perhaps a photo of the back of the cluster
Old Oct 16, 2025 | 03:27 PM
tlwjkw's Avatar
tlwjkw
'78.. looks like a normal gauge cluster from any view... there is nothing visually out of tha ordinary anywhere on it...
Old Oct 16, 2025 | 03:32 PM
ZIOGEO's Avatar
ZIOGEO
does it look like this?
Old Oct 16, 2025 | 04:06 PM
tlwjkw's Avatar
tlwjkw
no, its this one...
C3 1977-1982 Chevrolet Corvette Console Gauges Printed Circuit - CA
got one ordered.. mine is kinda messed up where tha fingers engage tha harness plug... so it needs a new one anyway......
Old Oct 24, 2025 | 07:14 AM
biackbenz's Avatar
biackbenz
Hopefully the new circuit board solved your issue.
If your lights are still dim I would suggest reading the voltage at each light With the dimmer at full brightness you should be getting 12 volts.
Let us know how this is coming along.
Old Oct 24, 2025 | 07:43 AM
tlwjkw's Avatar
tlwjkw
it did solve tha problem.. was testing with it "outside" tha car with a direct 12v to tha board.. no dimmer involved...
To instrument cluster lighting?
