power steering kit
I would rebuild a factory original control valve everytime over any reproduction replacement.
Hoses are sold by a number of manufacturers. Look for USA made.
Of you insist on saving money on the one part of a Corvette that is well known for problems. Well. No one can help.
I was wondering if the quality of the kit that was 250 was as good as the expensive kit. I have lots of time on my hands so I might go the Rock Auto route. Thanks!!!
It replaces all of the stock garbage with a new steering box, two lines, no ram, and no PCSV. You do reuse your power steering pump, though.
If you are insisting on keeping the stock stuff, you might be better off rebuilding the components yourself.
And using sub standard reproduction parts is just asking for trouble.
I have rebuilt or repaired the power steering on my red 77 more times than I can remember over the years.
The aftermarket replacement power steering control valves tend to have way to much slop in them at straight ahead. So almost everyone poo poo's the factory system because of this slop. Makes for play in the steering at straight ahead.
So, then they say convert it over to a Borgeson system. Which is a Jeep box with a adapter welded on.
If you wish your Corvette to steer just like a jeep. Then this is a fix.
However there are also threads on here with leaking Borgeson units. So that's not 100 percent.
Rebuilding original components, particularly the control valve is really the best way to repair the factory system.
many if not all parts are available from Rock Auto and Summit racing. Personally I would truly stay away from no name discount parts.
You may want to consider reading this thread: https://www.corvetteforum.com/forums...alignment.html
Its only been around one year in the car. So I have not had an opportunity to test the lifetime warrantee
I have not greased the control valve since buying it. I have been working on the interior so no need to grease until now. Thanks for the thread about greasing, I'll read it today.
https://www.corvetteforum.com/forums...uestion-2.html
Over many decades, Most US RWD coupes' and sedans' steering designs are (and have been) "front steer". Meaning the tie rod ends are forward of ball-joints.
In stock car racing parlance, C3 steering is essentially "rear steer". Meaning the tie rod ends are aft of ball-joints. Note: this usage does Not reference anything to do with rear axle.
Before pro stock car racing became inundated with spec chassis and spec motors, teams could choose front or rear steer. Today, in lower ranks, teams can order up or build chassis in either configuration.
So again, some Fords did also have rear steer and ram-assist. But, no fear, your C3 will never steer like a Ford. Although it will steer like a rear steer car; because it is rear steer. Again, Not about any rear axle.
Again my initial response was in context of an aside. And was simply to inform; that in addition to C3, there are more vehicles which employ rear steer and ram-assist. But in that sense only, the C3 is not unique.
I buy from Rock Auto, but I'm very careful about the actual supplier.
