Should have my new wheels and tires here this week 17x9 with Yoke tires.I think from what i have seen on the forum ill do the A/C Delco gas shocks but which spring will give me the best ride from what ive have seen the glass would be the best way if so which one.The cars a top off weekend special and Corvette Club crusier with the wife #5 ill add.I would be greatful for any advice anyone has.
Wayne :flag :grouphug:
Re: Best rear spring replacement for a 1980 (lobwedge)
Several threads in the archives on rear springs. I have the TRW one (rate 340) for my 1980 from Muskegon Brake. Others seem very happy with their springs from Vette Brakes (VBP). Several vendors also carry these springs. I don't know if you can go wrong.
The archives also have discussions on what spring rates and which shock absorbers are appropriate for your application.
Re: Best rear spring replacement for a 1980 (mapman)
Hello mapman thanks for the the update from my home town 23 years ago went to school at Goddard And WSU.Ill check the archives thanks for the info hey is the Gin mill still open?used to love that place and Angelos food on Harry I can taste the salad now.
Wayne out
17x9 Yokes... sounds expensive. Just make sure to get your suspension realigned after the new spring. If you haven't done the front, you may want to do that too, and get the whole car aligned with the new suspension. Don't want your $$$ tires to wear unevenly.
The 340 should be great. Not sure about the AC Delco shocks w/ a fiberglass spring, though.
Club Cards are gone!! :lol: :lol: I can't find a listing for the Gin Mill. :sad:
Angelo's has moved to Oliver and Lincoln (the old Spears). MUCH larger place, the food is still the same - wonderful.
If you have not been back, the canal route (MLK Blvd) is completed. Construction in process on East and West Kellogg - should be complete in 20xx. The Eastborough Duck Pond just was drained. Things change and remain the same.
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Best rear spring replacement for a 1980 (Pacin'California)
I am running the 340lb mono spring. Nice smooth ride, but you MUST replace the rear shocks.
Either get the VB&P shocks that are valved for mono-springs, or get an adjustable shock.
STOCK SHOCKS and others valved for the steel springs WILL NOT WORK!!
You will end up with a horrible rebound problem.
With that said, if you get the right shocks, it is a great improvement over the steel springs.
