Fuel Pressure Gauge Location
Old Dec 2, 2025 | 02:01 PM
C3FIXER's Avatar
C3FIXER
Default Fuel Pressure Gauge Location
I have a Edelbrock AVS2 Carb with an Edelbrock Banjo Inlet tubing connection which runs under the carb with an ofset 90 deg into an edelbrock fuel filterthen another 90 deg fitting that connectts to the metal tubing coming up from the original fuel pump. How do I install install a fuel pressure gauge without making any major changes. I see a lot of guys using rubber connections but that is not very safe in the long run. This is a 350 engine L82 with edelbrock E series alm heads. Any photos out there would be helpful. THANKS!!
Old Dec 2, 2025 | 05:55 PM
Piersonpie's Avatar
Piersonpie
I would email Lars at V8fastcars@msn.com and ask for his “How to build a fuel line” paper.
