Bolt Torque?
Old Dec 17, 2025 | 10:04 AM
mbp's Avatar
mbp
Default Bolt Torque?
Hello. Can anyone tell the torque on the 3/8" bolt that attaches the bell housing to the block? I can't seem to find it in the A.I.M..It's on a 1969 4 speed if that makes any difference. Thanks in advance.
Old Dec 17, 2025 | 10:28 AM
ctmccloskey's Avatar
ctmccloskey
Some say 30 foot pounds and many say 37 foot pounds of torque to secure the 3/8" bolts to the bell-housing on a C3 Corvette.
Old Dec 17, 2025 | 01:02 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Two ugga duggas.....
JIM
Old Dec 17, 2025 | 02:54 PM
bashcraft's Avatar
bashcraft
JIM
I've never used a torque wrench on bell housing bolts, nor have I ever heard of anyone using a torque wrench on them.
Old Dec 17, 2025 | 03:26 PM
Rebelyell's Avatar
Rebelyell
Suggest a few simple straight-forward precautions:
Before you put any real force on BH bolts
Ensure faces of both block and BH are very clean
Chase threads in block's face, and Ensure BH is firmly seated to face of block, all around.
Old Dec 18, 2025 | 08:19 AM
redwingvette's Avatar
redwingvette
Tighten till it breaks and back it off a 1/4 turn LOL
Old Dec 18, 2025 | 09:44 AM
Wally8's Avatar
Wally8
Cruising
When you can't find a torque in a maintenance manual you should look up standard torque which depends on bolt size, thread and grade and if you're using lubricant. Here it is for 3/8".
Typical Torque Values (3/8"-16 UNC)What you're putting the bolt in to matters as well since you may not torque to a spec if it's in aluminum or something like that. Example being rocker studs in an aluminum head.
Wally
Old Dec 18, 2025 | 02:54 PM
carriljc's Avatar
carriljc
mbp
One of my Manuals say 30 ft-lbs and the other says 40-50 ft-lbs.
I believe that last time i did mine I went to 35 ft-lbs with blue locktite..... so I'd recommend that.
And, YES, I use torque wrenches.
Old Dec 18, 2025 | 08:18 PM
USMC6113's Avatar
USMC6113
German torque, Goodentite!
Old Dec 18, 2025 | 09:12 PM
sphil's Avatar
sphil
You must be an aircraft mechanic😂
Old Dec 19, 2025 | 04:03 PM
71 Vert LS1's Avatar
71 Vert LS1
I thought it was tighten the bolt until it strips and then back off it off a 1/2 turn? LOL.
Old Dec 19, 2025 | 04:22 PM
sphil's Avatar
sphil
Thats for large hardware!
To Bolt Torque?
