Q Jet specialist
Popular Reply
Unfortunately, the Echlin/NAPA kits have lost all and any level of product quality they once had. The accelerator pumps are junk (they swell up and seize in modern pump gas); they have the wrong needle/seat assemblies in them; kits are frequently missing parts or have incorrect parts in them; and they have increased prices to the point that it is obvious that they don't want to sell carb kits or parts anymore. If you're going to buy a "kit" for the truck carb, get your parts from Cliff Ruggles - he is the only remaining source for good quality Q-Jet parts.
Just my opinions and suggestions...
Lars
There are plenty out there and it may be a better idea to find a clean auto carb core to start with.
If you do a bit of searching here, you will find plenty of help from Lars and others on this same subject.
One thing I would recommend is to get a kit and tuning parts from Cliffshighperformance.com.
Pretty much the best kits available and some of the best back up tech from Cliff.
Might as well pic up a copy of Cliffs Quadrajet book as well so some if the tweeks and mods are understood. Lots of good info from this book.
If I am not mistaken I believe Lars uses his kits and parts for the work he does.
Lars
[b]He rebuilt is 1978 OEM Quadrajet 5 years ago, and still has starting problems when the engine gets hot. [/QUOTE]
I'm beginning to believe that a Quadrajet equipped motor that is a bit reluctant to start when hot MAY be due to today's ethanol contaminated fuel.
My '76 L82 with stock Q-jet carburetor gets stage-fright when attempting to start when the motor is hot. Not a problem to start immediately after shut-down, but if allowed to sit hot for 10 minutes or so it requires more starter time than when the motor is cold.
Jason
I disassembled my carburetor and discovered the two aluminum plugs that seal the cross-drilled holes in the bowl were leaking. Ah ha, that's the problem I thought. So, I carefully drilled out the plugs, tapped the holes and installed set screws with fuel-resistant epoxy on the threads.
Reassembled the carburetor, installed it on the intake manifold, started up the motor and the hot-start problem still persists.
Jason
Jason
Except I'm confused. Leaving the fuel line disconnected/loose for 10 minutes usually causes what problem?
My interpretation of your test is that if the motor starts after the 10-minute period without having to crank on it like the Hurdy Gurdy man, then the float level is too high and that by relieving the upstream pressure, overflow from the bowl to the intake manifold was mitigated.
Or, have I misinterpreted your test?
Jason
Eliminating the residual fuel pressure after shutdown means that that the bowl won't continue to fill with fuel if you have a fuel level control problem. A fuel level control problem can be caused by several different issues, and will cause fuel to "dribble" into the intake after shutdown. If the problem goes away after you've immediately disconnected the fuel line after shutdown (and then re-attached it before starting), it means you have an issue with fuel control. A high float will not generally cause the problem unless your float level is so high that the fuel level is above the level of the main discharge nozzles.
The float needle and seat are less than a year old, purchased from Cliff Ruggles, so I don't suspect them as the problem. Moreover, I've replaced the aluminum cross-drill plugs with set screws and epoxy, so no more leakage from those areas. The only thing remaining is perhaps a misadjusted float. But I'm getting ahead of myself. Let's see what tomorrow's testing tells us.
Jason
The main thing I learned from this was to only make one change at a time. Had I replaced carb and got that tuned then replaced distributor I want to believe I would have known it was a junk aftermarket distributor.
I would like to apologize to Capt Ken for jumping into his topic; I hope I'm not inconveniencing you too much.
Yesterday it was 83* F in Katy, Texas and today it was 51* F at the time of my carburetor test. I ran the car for about 12-15 miles at mixed speeds, disconnected the fuel line from the carburetor and let it heat-soak for 10 minutes. I reconnected the fuel line and started the car and did not experience a hard-start problem. So what does that mean?
I'm concerned that it simply was not hot enough to cause hard starting. I'll wait for an 80* F-plus day and perform the test again.
But in the meantime, observing the same test results at higher temperatures suggests a float needle/valve leak. So, I'll install a new needle and seat, notwithstanding I replaced them less than a year ago from a parts kit purchased from Ruggles.
My ignition system is stock, except for new wires, dizzy cap, rotor and spark plugs.
So what else could the problem be?
Jason
Jason
Jebby
