T-Top Velcro Rivets
Old Jan 6, 2026 | 06:23 PM
Floydy's Avatar
Floydy
Default T-Top Velcro Rivets
Drilled out the rivets holding the Velcro fasteners to the T-tops on my 72 coupe. Some the rivets have fallen inside the cavity between the T-top inner and outer skins. They have added to various other pieces of detritus already in there rattling around. Any way to get these bits out without major surgery?
Thanks in advance.
Old Jan 6, 2026 | 09:01 PM
Alan 71's Avatar
Alan 71
Hello,
This happens!
Find a place that can take a drilled hole of about 3/4".
Locate it in a place that will be covered when you install the vinyl liner.
Then shake shake shake!!
Regards....
Old Jan 6, 2026 | 09:08 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yup, in one corner. I drilled about a 1inch hole. Gets out the weatherstrip pins and those rivets. Shaking and a shop vac.
Old Jan 7, 2026 | 08:34 AM
Floydy's Avatar
Floydy
Originally Posted by Alan 71
Hello,
This happens!
Regards....
Thanks Alan, great advice. Thank you.
Old Jan 7, 2026 | 08:35 AM
Floydy's Avatar
Floydy
Great advice, thank you! Adding the shop vac to the mix is a really good suggestion.
Old Jan 7, 2026 | 08:43 AM
Alan 71's Avatar
Alan 71
Hello F,
Be careful when you drill.... the outer fiberglass 'skin' is right there...quite close.
Regards....
Old Jan 7, 2026 | 09:30 AM
LT-1 kid's Avatar
LT-1 kid
very good advice Alan,
To T-Top Velcro Rivets
