Piston Stop Top Dead Center Finding Tool?
Comment on related topic. I bought an additional distributor cap. In my case it was an HEI cap. I took a Dremel tool with a cutoff wheel disk installed, and cut a window in the cap above the number 1 cylinder/sparkplug wire connector. This allows me to see that the distributor rotor is immediately above the number 1 spark plug terminal.
for those so inclined, clear, see-thru caps are available. Not my choice; fugly.
I guess I always fall back to the way I learned how to do things.
Remove Driver VC
While closely observing #1 Intake rocker, And All While you roll (clockwise) damper over.
Immediately After #1 Intake closes, the instant the Zero Groove arrives t TDC mark, that is #1 TDC
* Waay back, during HS, I rode a '49 pan to school. I learned back then, how to set both its point gap and ign timing Very close w/ no more than a matchbook, a cellophane cig pack wrapper, a crescent and a screwdriver. Oh well, Sometimes, seeing the forest for the trees is easier said than done.
Remove Driver VC
Immediately After #1 Intake closes, the instant the Zero Groove arrives t TDC mark, that is #1 TDC ....
The engine recently came back from the dyno shop.
They used my distributor, set everything, and used their plug wires.
So when I brought the engine home I had no idea where the engine stopped in reference to number one cylinder top dead center on the compression stoke.
The MSD distributor cap does not identify what post the number one plug wire plugs into.
So I simply need to turn the engine over so the number one cylinder piston is at top dead center on the compression stroke so I can correctly install the plug wires.
This has nothing to do with the engine assembly.
The other thing you missed by not reading this thread is that I am just looking for an easy way to rotate the engine and set the engine number one piston at top dead center on the compression stroke.
Since there are no wiring harnesses, battery, or battery cables installed in the car, just bumping the starter with the ignition key isn’t and option.
Rotating the engine using the crank tool isn’t an option because the harmonic balancer and crank pulley are installed.
So thanks to the helpful suggestions of other member I ordered the remote starter tool, will connect the necessary wiring and turn the engine over using the starter and battery power.
Thanks for your help.
You made a similar erroneous accusation soon after I registered.
Apparently someone else bolted your heads to your block; motor's builder, I suppose. Glad for ya, that you're finally gonna have a remote starter on hand.
I showed you a pic of an alternative tool for turning damper (+crank) while damper on snout. Heck, you could screw three bolts into damper and use a long screwdriver to turn it as well.
Do you recall your 'warm n princely' welcome to me; soon after I registered ? I do.
Good luck w/ your project.
JT
JT
I have both the 3 bolt to the crank tool pictured in post #12 and the starter bump tool.
I have used both and I much prefer the crank tool.
It is slower and more precise. Easier to get exact alignment.
That is why I thought you might like it too.
I also like the wood dowel method mentioned as well.
I made line marks with a sharpie and it worked extremely well for finding TDC, if unsure.
Not that you need that in your case.
I only asked originally because I was looking for easy ways to turn the engine over without disassembling anything.
In the past I have used the crank bolt with the plugs removed and a finger in the spark plug hole which has always worked great and gotten me close enough to tdc to do what ever I needed to do.
I installed an ARP crank bolt in the snout so I’m not concerned about breaking a bolt, however over the years this method has become frowned upon so I was trying to find a better, safer and more widely approved method.
I apologize if I got a little upset in my earlier post.
I just can’t stand those who always want to point their finger at someone and indicate that something wasn’t done correctly when they know nothing about what or how it was done.
Thanks to everyone for their helpful contributions!
Greg
The distributor hasn’t been removed and I did look at the distributor cap to see if maybe they did mark it in some way.
They did not.
I was in the room when the last dyno run was completed and they didn’t set the number one cylinder to tdc.
We usually try to put #1 at about 5:00 but it can function anywhere.
Engine Rotation Adapter - Part #66782
With using the remote starter button I’ll find tdc by just bumping the engine with my finger over the number one spark plug hole.
I’ve been busy cutting and installing the new Thermo Tech Supressor Cool It Mat on the interior firewall over the last few days.
It’s time consuming but I have it all covered and I hope to have all the seams taped off today.
Next up is installing the new battery, make and install the new battery cables, then I’ll be able to use the remote starter and get the plug wires made up and properly installed.
Thanks again for all the help everyone!
I look at the #6 rockers and when one rocker is closing and the other is opening I watch to see when they are both are exactly equal. They are now in overlap and #1 piston will be at TDC. Try it, it works, it basically has to.
After removing the fan, I was able to turn the crank by hand with a standard ratchet and socket (5/8 I think). Yes, it was hard! Especially with the AC belt in the way, fan shroud, and no other plugs removed... I will probably look at a different method next time I have to do this.
