Piston Stop Top Dead Center Finding Tool?
I bought one from Summit Racing a couple weeks ago.
I just got my new battery cables and battery installed so now I can bump the engine over using the starter and find TDC with my finger in the #1 hole.
This will help me determine the starter is installed correctly, the fuel pump rod in installed correctly and with the plugs all out I should be able to pump a little oil before I start the engine for the first time in a couple years.
By the way,
I was able to install the transmission tunnel insulation with the TKO 600 installed.
However I found the piece fit horrible so I’m removing it and using Thermo Tech adhesive backed heat barrier instead.
