Shifter Won't Move
Old Feb 13, 2026 | 04:34 PM
Steve Stroman's Avatar
Steve Stroman
Default Shifter Won't Move
My shifter won't move very far after a drive. It is sitting in park, and with the key in the on position, it will move just a bit, but not far enough to get into reverse. It has happened before, and after I monkeyed with it for a while, it worked fine. But I'm not sure what I did to make it work. The cable is NOT frozen, but I can't figure this out. I know this is a crappy description, but I don't know how else to explain it. Feel free to ask any questions.
Any help would be appreciated.
Old Feb 13, 2026 | 04:57 PM
Steve Stroman
Update: Again, not sure what happened but it moves freely now. Still wouldn't start, so I bypassed the NSS and it started right up. I may have to disconnect the cable to the transmission from the column, the bracket is pulled away from the firewall and I'm not sure how to get to the bolt that holds it to the firewall.
Again, any help appreciated!
Old Feb 14, 2026 | 12:15 PM
MelWff's Avatar
MelWff
You can disconnect the steering interlock cable from the lever on the firewall and tie the lever in the up position.
To Shifter Won't Move
