'72 hp
Old Feb 22, 2026 | 02:01 PM
Rebelyell's Avatar
Rebelyell
Originally Posted by Piersonpie
Same thing, but right out the manual
Proof-reading skills not optimal as I age.
I don't spot a reference to either L48 or ZQ3 or RPO in conjunction with Base aka Standard engine in the above manual's page published September 1973.
Can you please point that out or circle it ?
Old Feb 22, 2026 | 02:07 PM
Piersonpie's Avatar
Piersonpie
No RPO codes, just showing the list of possible engines for 1974. I think we all know the 195 horse is the L48.
Old Feb 22, 2026 | 03:30 PM
Rebelyell's Avatar
Rebelyell
No, there are many who do Not KNOW what the correct RPO is. Plenty of guesses and assumptions; some right, others not.
Old Feb 22, 2026 | 03:35 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I judge an L48 by its camshaft.
Every 300 gross HP 350, or ~270 gross HP due to compression, from 67 to ~ 79 used the same camshaft.
The 67-70s had 10:1 CR flattop pistons.
The others had dished pistons with ~8:1 CR
A few minor variations, a few had steel cranks, a few had 4 bolt blocks, a few had EGR intakes, none of that matters a bit.
Same basic engine.
A ZQ3 is the same as an L48. Nothing special about an ZQ3 code.
Been hearing that one for years.
Old Feb 22, 2026 | 04:52 PM
jb78L-82's Avatar
jb78L-82
STANDARD ENGINE Standard EightCylinder Engine Ordering Code L48 Turbo-Fire 350-4/DE 8-Cylinder 350-cи-1n displacement
Did you not see my post "16 above???? That quote, AGAIN, is from gmheritagecenter.com, the official data source for the GM OEM owner manuals for GM cars and other documents for GM cars. The quote above is directly from that GM source for a 1974 corvette and is directly in line with my excellent memory that the 1974 Corvettes with a SBC 350 engine were either the L-48 base engine or the Hi performance L-82. You can clearly see the base engine is referenced as the L-48 in 1974. Go their website for yourself and look up the official documents for any year corvette and you can stop debating this question. Hope that helps!
Old Feb 22, 2026 | 05:32 PM
Rebelyell's Avatar
Rebelyell
Originally Posted by kansas123
Someone asked a question about a de-smogged L-48, and it made me wonder if de-smogging it raises the HP and how much. Just curious. ('72)
If yours is a '72, repeat '72, and it's either an L48 or ZQ3, it has relatively low compression ratio. Whatever de-smogging is, unless you either Change piston crown Or combustion chamber volume, it cannot raise compression ratio nor increase power significantly. If it runs fine on 87 now, it should continue to do so; unless and until you make a major change of hard engine parts (while effectively & significantly raising static compression ratio).
Again, ALL of em (C3) had compression ratio significantly reduced beginning MY1971
Old Feb 22, 2026 | 07:26 PM
stingr69's Avatar
stingr69
Yes. 76cc heads and dished pistons. 71 and up.
Old Feb 24, 2026 | 01:50 PM
kansas123's Avatar
kansas123
Thanks for all the throttle responses, nice lively discussion with great info.
