Head gasket re use
Old Mar 1, 2026 | 01:50 PM
Logan B's Avatar
Logan B
Default Head gasket re use
I am in the process of reassembling my 1973 corvettes 350 and as I was torquing the heads down one of the threads in the block started to pull, all of the other bolts made it to the arp recommended 70 ft lbs. I took the head back off so I can repair the threads with a time sert. I am using fel pro 1003 gaskets and I’m wondering if I can save the money and re use the gasket being that it was never ran and the gasket was only installed for a few hours.
Old Mar 1, 2026 | 02:36 PM
Crimson Thunder's Avatar
Crimson Thunder
As long as its installed on the same side I don't see a reason not to reuse it.
Old Mar 1, 2026 | 02:50 PM
jjcoledo3's Avatar
jjcoledo3
2 silver vets
It is already crushed. Why take a chance. Spring for a new one and be sure.
Old Mar 1, 2026 | 06:24 PM
Rebelyell's Avatar
Rebelyell
nothing so special about 1003 gasket, except package (& price) reads Performance.
why not choose another, less expensive, but quite similar gasket, that's Not labeled Performance ?
perhaps felpro P/N 7733PT-2
Old Mar 1, 2026 | 09:21 PM
C3 Stroker's Avatar
C3 Stroker
Re-crushed gaskets have sometimes been used, but I never would. A re-crushed head gasket torqued to the same specs cannot seal exactly the same as the first fastening.
Old Mar 2, 2026 | 04:54 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
A blown or leaking head gasket is just no fun. Why take a chance.
Old Mar 2, 2026 | 07:56 AM
Tiger Joe's Avatar
Tiger Joe
i went thru this exact same thing this fall on my 427. just about everyone told me it would be ok to run but for the price of a gasket i didnt chance it. if there was ever anything abnormal with that engine, i would always be questioning that gasket
Old Mar 2, 2026 | 01:24 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Wouldn't bother me a bit if it isn't damaged.
JIM
Old Mar 5, 2026 | 09:28 AM
ctmccloskey's Avatar
ctmccloskey
While testing my engine for clearance between the pistons and cylinder heads I used a couple sets of head gaskets. I chose to use new gaskets for the final build because the head gaskets were deformed/crushed during the installation and testing.
New gaskets are likely to seal better, why take a chance at having to remove the heads again? Just be sure to use the same brand gasket on both sides to keep the compression from being affected.
Valve covers gaskets can be re-used because they are easy to change. I am not that keen on removing the heads just for a gasket.
To Head gasket re use
