1982 Will not idle
Old Apr 10, 2026 | 01:19 PM
Belmar1982's Avatar
Belmar1982
Cruising
Default 1982 Will not idle
I purchased a 1982 project car last year, it was sitting in a garage for a long time. Replaced the fuel tank and pump with a new one from Volunteer Vet. Cleaned out all the fuel lines and replaced the hoses and put in a new fuel filter. Not to mention a new battery and plugs.
The car started up but then slowly died.
Have not been able to get it to idle since then.
I have replaced the following:
Throttle Position Sensor
Oil Pressure Switch
Fuel Pump Relay
Xfire Fuel Pressure line between the injectors
I have done the following:
Looked for a code by jumping pins a & b all I get is 12, 12, 12 no other code
Confirmed all the fuses are good
Hot wired the fuel pump at the oil pressure connector, get fuel pressure the car will not start at all
Confirmed I am getting spark
Cleaned the ECM Connectors
The car will start and run for 2 seconds then stall. If I put my foot on the gas it will run longer but eventually will stalls out. See attached movie files of it running.
I am looking for some suggestion of where to go from here.
File Type: mov
Old Apr 10, 2026 | 02:52 PM
Fly skids up!'s Avatar
Fly skids up!
From the video it seems to be running out of fuel. Try pouring some gas down the throttle bodies and see if it stays running longer. If it does you'll know it a fuel issue.
Old Apr 16, 2026 | 11:27 AM
Belmar1982's Avatar
Belmar1982
Cruising
I did this same results.
Im thinking the ECM, seem to start initially the stops when the ECM is to take over. I looked for codes get 12,12,12 but the CEL stays on all the time.
Old Apr 16, 2026 | 05:43 PM
Fly skids up!
It's hard to troubleshoot over the internet however it's probably one of your sensors are not feeding the ECM the correct information. Do you have access to a scan tool because that will tell you immediately what's going on.
Old Apr 17, 2026 | 08:44 AM
MajD's Avatar
MajD
Belmar,
I didn't read in your post where you checked the TPS voltage after you replaced it. The voltage should read about 0.5V at idle. There is a procedure to adjust it. If you did this, then the problem is obviously somewhere else.
MajD
Old Apr 17, 2026 | 09:15 AM
brushmor's Avatar
brushmor
Something is causing the stall from switching to startup mode in to open loop. The fact that you are getting code 12 just means the primitive computer can't figure out what's out of whack. In absence of a scan tool, the things I'd check:
  • TPS voltage (as mentioned)
  • Fuel pressure. You know you have fuel pressure but is it enough?
  • MAP voltage
  • Coolant temp sensor voltage
Also, I'd plug the vacuum port for the thermac while you are troubleshooting.
Old May 12, 2026 | 12:06 PM
Belmar1982's Avatar
Belmar1982
Cruising
Well after some more testing I could see I have spark at start-up and I could see gas coming from the injectors. But the car would just cut out. I went old school and replaced the coil...bingo. I had an intermittent coil. Never had a coil like that they always have been either bad or good. Now I can move on to brakes.
To 1982 Will not idle
