Power steering
Old Apr 12, 2026 | 05:16 PM
Bigbee69's Avatar
Bigbee69
Default Power steering
Hi folks. The p.o of my 69 had the ps lines installed in a precarious position hanging below the power cylinder. I moved them. Refilled the fluid and performed all the bleeding procedures and it jerks when turning right and the cylinder is leaking. Any ideas ?
Old Apr 12, 2026 | 07:22 PM
Bikespace's Avatar
Bikespace
Borgeson swap!
But seriously, there is a procedure in the shop manual for centering the power steering control valve (PSCV).
Zip Corvette was the first link I found with the instructions.
https://www.zip-corvette.com/amfile/...product/10083/
If it is anything like my 79, the system will continue leaking after you replace everything twice, and the only solution for that is a Borgeson swap (or manual conversion). YMMV, though, and you may have luck kicking the can down the road by rebuilding one part at a time.
Old Apr 12, 2026 | 07:56 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Read through this recent post asking about PS jerking.
https://www.corvetteforum.com/forums...post1609570003
If the system was opened to air, you've got to bleed it. Folks describe how-to in the thread above.
Old Apr 16, 2026 | 05:35 PM
LT1M21Vette's Avatar
LT1M21Vette
"Turn the steering wheels from lock to lock a minimum of two times. This will bleed any remaining air out of the power steering system."
To Power steering
