Help with backfire thru carb
Old Apr 16, 2026 | 08:10 AM
azmusclecar's Avatar
azmusclecar
Default Help with backfire thru carb
I have a 1981 C3 with the computer or electronic carb removed. It has been replaced with Edelbrock AVS, intake, distributor.
I have an issue where if I slowly raise the rpms, the engine does ok. As soon as I hit the trottle for a rapid increase, it backfires thru the carb.
I replaced the accelorator pump in the carb. Made sure the squirters were receiving ample flow. I checked the timing.
I set timing at 4 degrees BTD.
When I raised the rpms slowly to avoid the backfires, I could only get about 25 degrees ALL IN at 2K rpms........
Could it be a broken intake or exhaust valve?
All new spark plugs.......idles fine, at 600 rpm, starts right up with just a turn of the key.
Where do I go next to try to isolate the issue???????
Thanks,
Baffled AZ in AZ.
Old Apr 16, 2026 | 08:49 AM
DaveL82's Avatar
DaveL82
Timing should be 12 btc for a baseline with vacuum advance not connected and line plugged .
What distributor do you have? HEI or other. If an ignition problem, this is typical of an HEI ignition module failing especially after the engine gets to temperature and distributor gets hot.
Old Apr 16, 2026 | 11:34 AM
Piersonpie's Avatar
Piersonpie
Assuming your 4 at idle and 25 at 2K is with the vacuum advance unplugged you have a 21 degree swing of mechanical advance. Meaning to get a proper spec of 36 total you’ll want to set your timing at idle to 15, again, with the VA unplugged. 2K is also far too low to have all of your mechanical timing all in. I would add heavier springs until it’s all in at 2,800-3,000 RPM. Unless you have 11:1+ of compression you should not be running into pre ignition issues with this setup.
Old Apr 16, 2026 | 12:16 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Backfire thru carb is most often a lack of timing issue.
Do you know what your timing curve specs are?
A performance timing curve should solve that.
Old Apr 16, 2026 | 09:52 PM
azmusclecar
Thanks to all that have posted replies......I'll focus on the above parts and contributors to what may be the problem.
I'll report back on results.........thank to all.
AZ
Old Apr 17, 2026 | 10:22 AM
azmusclecar
The compression of this enemic L81 is still 9:1
Old Apr 17, 2026 | 10:24 AM
azmusclecar
It's an Edelborck HEI distributor........the stock OEM distributor was replaced with carb, and intake.
Old Apr 17, 2026 | 10:27 AM
azmusclecar
I have been having the vacuum advanced plugged......when I check or set timing. I've tried the 15 degrees BTD to try to get to the 35 all in and it seems as the rpms
go above 2000 to 3000 the carb popping begins........
I'll pull the HEI module.......and replace........any siggestions on a relaible replacement??????????
Old Apr 17, 2026 | 10:57 AM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
https://www.corvetteforum.com/forums...long-post.html
Old Apr 17, 2026 | 11:42 AM
peters220's Avatar
peters220
Check for worn cam lobe or broken valve spring. This is typical for your symptoms. JP
Old Apr 17, 2026 | 01:29 PM
Bikespace's Avatar
Bikespace
By all means, fix the timing to the current best practice.
However, I doubt 10 degrees of retarded timing is enough to cause a backfire through the carb.
Sounds like a massive vacuum leak, and/or a valve issue.
Old Apr 17, 2026 | 01:42 PM
azmusclecar
I'm leaning toward the broken valve spring........but of course........I was wrong once...........I hate to repeat that
Old Apr 17, 2026 | 01:44 PM
azmusclecar
WOW. this looks like one of my college courses.......thanks for the link............
Old Apr 17, 2026 | 06:16 PM
Rebelyell's Avatar
Rebelyell
All good suggestions, ALL.
Also, valve(s) Not sealing; via bent or burned or Both.
Additionally, perhaps some valve(s) adjusted too tight.
systematic compression checks; both dry & wet can help rule in-rule out.
Old Apr 17, 2026 | 07:32 PM
azmusclecar
Maybe time to call in a pro...........find a mechanic whos pay grade is way over my head and skills..
I considered pulling the valve covers and looking for the issue. At my senior age....working on and under my C3 can be considered proof I'm
ready for the guys in white coats. I've learned to stay within my lane and not create even more problems with mistakes and bad ideas.
Old Apr 17, 2026 | 08:03 PM
peters220's Avatar
peters220
Is there a Corvette club in your area? JP
Old Apr 17, 2026 | 08:48 PM
azmusclecar
Yes and no. I'm 50 miles from Tucson which I guess would be the closest........
To Help with backfire thru carb
Old Apr 17, 2026 | 09:22 PM
Rebelyell's Avatar
Rebelyell
Cannot see a bent or burned valve by looking under valve cover. It's valves' heads that don't seal against valve seats in combustion chambers; those only seen by pulling head from block. As said, can be tested in situ.
And yes sir, I get that senior thing; daily.
Old Apr 18, 2026 | 11:08 AM
azmusclecar
My thoughts on pulling the valve cover was just to inspect for a broken spring. I realize it does not help if it's a burnt or stuck valve. I thought the removal of the valve covers would be a good place to start since the timing has been set and reset and a slight noted but soft miss is a telltale sign of something else. I have all new vacuum lines installed, new rubber, even new plastic connector trees etc.
So, I'll chew on the valve cover removal and seeif it's the short path to what may be a long path to repair. I have nothing to lose removing the valve covers.
Old Apr 18, 2026 | 11:32 AM
peters220's Avatar
peters220
You can also check the valve lift of each valve with the rocker covers removed. Look at each rocker and see how much it moves. Also lift the rockers to check how loose they are. The lobe will be almost flat to cause your symptoms. JP
