Help with backfire thru carb
Azmuscle, did the engine operate well up to a point with the problem appearing after intake change, or has your ownership always had this issue? Did you do anything to the valve lash when the intake was changed?
A broken valve spring isn't likely to affect wet-dry compression tests. But, tech should be able to visualize that with just a valve cover removed.
My LS6 had bad compression on two cylinders. It was a lot easier to diagnose with the engine out of the car, but here's my journey. Turns out two (exhaust) valves were sticking open due to something the engine had "eaten" (likely the smashed plastic intake manifold).
A leakdown test, and a borescope, both confirmed the diagnosis. I ended up pulling the heads to clean the valves. Again, a lot easier with the engine out of the car. Hopefully your car doesn't need that.
https://www.corvetteforum.com/forums...-2002-ls6.html
i didn't notice any idle issues like a miss or anything on the initial inspection and drive.
The really odd thing was I heard a POP as I was leaving the seller's home and just thought it was an anomoly. The Vette needed all new rbakes so I drove it home and
spent a month installing all new brakes. I'm old I work slow.
I didn't think much of the POP until it did it again. So I started investigating asking questions, watching You Tube videos and posting here. Most replies came back it's a
timing issue so I plugged the vacuum advance and used a dial back timing light and tried several suggestions. The timing mark with the light was okay at idle but when
I began to increase the revs to see what the all in was, the popping happened. It ONLY HAPPENS when the rpms are increased RAPIDLY. You can slowly raise the
RPMs and eventually at a point it pops. But if you do a hit of throttle it pops almost instantly. I did install a new accel pump in the carb.
So that is where it sits. I can drive it if I need to using slow rpms increase. I drove it 75 mph and the tach read 2200 and no pops. But try to add quick throttle and the POPS returns.
Sorry for the long story but I'm trying to give as much info as I can.
I'm hoping its JUST a broken valve spring. The engine only has 61K on it. If, and only IF the engine comes out, I need to consider a crate install since the enemic 190 HP on the 1981 is dismal BUT at my age I just wanted to end my days left with a nice driving Corvette WITH A/C and a 4 speed. As I said, I hope and pray it's only a broken spring.
i didn't notice any idle issues like a miss or anything on the initial inspection and drive....
timing issue...
Someone suggested a vacuum leak; would be easy to see if you can snug the intake bolts and carb mount bolts.
I'm unfamiliar with Edelbrock AVS so can't offer anything specific, but if the valves and springs check out, it seems like a transfer problem from primary circuit to secondary (mechanical or vacuum activation?).
The 2000-3000 rpm range where where you get your "quick throttle" pop, is also about where the secondaries cut in.
It could be going very lean. Just momentarily.
That would usually just give one big pop.
Check the Eddy directions on how to adjust the secondary air valve.
"Looser" is not faster.
This is a pretty critical setting, your prior owner could have "messed" with it.
But there is a lot of guessing going on here.
It sounds like you need to do some basic trouble-shooting.
Multiple pops could be a valve / combustion / firing issue.
In that case, the first thing I would do would be a compression test, and then a leak down test. Any valve sealing problems would show up.
Then I would measure the valve lift on all valves with a micrometer.
Those test should rule out any mechanical, ring seal, valve seal, cam lobe issues, or help identify them.
One pop could be so much simpler....
Not good,not good at all.........
Dry Test:
1-78
2-77
3-78
4-73
5-75
6-72
7-73
and least but not last
8-60-62
Looks like I done bought me a worn out engine......and how can you wear an engine out in 61K ORIGINAL MILES??????????
Maybe a fat running carb dumping fuel washed the cylinder walls down and the rings paid the price. With these numbers, I wasn't about
to do a wet test.
So the buck stops here trying to figure out where to go and what to do. My car buying history reads like EPIC FURY.......the seller wins and
I'm the one paying the price. If you think education is costly, try stupidity.
No more posts until I figure out what to do and NO LS SWAP! My money at age 75 can't handle that but a free donation and install will be accepted.
And appreciated..........thank to all........who offered help.
AZ
With the determination the engine is wore out, I stopped diagnosing and turned to alternative decisions. Time to move on, to what and where
I'm not sure..........but life goes on.
But if you have a lead on a crate engine, that might be the fastest way to get back on the road, if you can find someone to swap it.
Best of luck!
