Renewing Clutch Cross-Shaft
Old Apr 17, 2026 | 05:17 PM
The_JC_L46's Avatar
The_JC_L46
Default Renewing Clutch Cross-Shaft
Hey all, got another one…
So I’ve got a ‘click’ in my clutch cross-shaft: pushing down, about 3/4 of the way down, consistent, heard & felt in pedal, not so much on release.
1969 L46/Muncie, original equipment for reference.
Before I dig into the release fork and TO bearing, I’m going to renew/replace the cross-shaft and related pins, clips, seals, etc…*
[*see waaaaay below; it’s just a parts list]
The A.I.M. has the breakdown; the service manual has stated to use “graphite grease”**; this forum has suggestions / plans / ideas for filling the grease cavity with ‘something to take up that space’.
So I’ve got a plan, but want to ask for a few pointers…
**It’s been said chassis grease [ball joints, tie rods, idler] is acceptable. If you’ve got another suggested grease, what do you use?
I plan to use Valvoline Multi-Vehicle High Temp Red Grease, same as steering/suspension. StaLube Moly-Graph is also favored; Valvoline Moly-Fortified Gray is an option, too. …?
Has anyone had success with a “filler rod”?
Wooden dowels were used, post #8 here: https://www.corvetteforum.com/forums...storation.html
I’ve got a POM rod, 3/4”Diam x12”, and since it’s plastic (Delrin), has low friction, is resistant to oils & grease, with a reasonable density, and easy to fabricated/“machine”, I’d think it’s a good idea for a filler. [Math comes back at ~0.20lbs for 3/4”x8” rod; less after a groove is made.]
Test-fit and it drops right into the test cross-shaft, feels like a good modification, I’m open to experimenting with this and reporting back, worst case scenario, it’s an expensive grease-removal rod.
As far as assembly goes…
J219, UPC 7, Sheet C 1 in the A.I.M. is my reference for rebuilding, BUT! what about the engine-side ball stud?
Does it get a nylon seat [1] like the frame-side?
Inside the shaft?
Do I need 3 seats per shaft:
2-frame-side (in/out) + 1-engine-side (in) ?
Or just 1 like the diagram?
…or just one on each side, installed before the pivot-***** go in?
@DUB mentioned making sure the engine-side ball stud is tight.
Post #14, here: https://www.corvetteforum.com/forums...tore-tips.html
Any tips on sealing the threads?
RTV?
Loctite 242 or 243 [blue]?
Aviation sealer #2 ?
Other ideas?
Also, I can’t seem to find a spec for “acceptable amount of movement” in the shaft.
Up & down should be ‘none,’ but rotates without binding.
Side-to-side? 1/4”? 1/16”? It’s gotta have some, right?
Just trying to get this right on the first go-‘round.
Thanks!
John
Parts List, New/Replacement, on-hand, FWIW…
Ball studs, engine & frame
Nylon seats, 3 of ‘em
Special Washer [5], 2 of ‘em
Anti-rattle springs, installed (wish they were anti-click)
Return spring, installed
Cross-shaft (testing! / to renew & install?)
Fork pin + cotter pin
G-clips
Retaining clip
Felt seals
Rods: pedal & clutch-fork
EDITS: formatting
Old Apr 17, 2026 | 11:22 PM
Crimson Thunder's Avatar
Crimson Thunder
I've heard good things about the Speed Direct clutch rod upgrade kit. It uses heim joints for a smoother clutch operation. It will probably be the next thing I buy for my car.
Old Apr 18, 2026 | 05:25 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My rule of thumb is always, dissassemble, verify what if anything needs replacement. Then, and only then order parts.
Old Apr 18, 2026 | 08:09 AM
ctmccloskey's Avatar
ctmccloskey
I have the Speed Directs Rod Links kit on my 1968 Corvette and it works great. The reduced friction is noticeable and it works very smoothly.
It would be easier to just replace the parts with the Speed Direct Rod links kit. This is an improvement for the car but includes no permanent modifications to the car.
Old Apr 18, 2026 | 09:15 AM
The_JC_L46's Avatar
The_JC_L46
That's my philosophy most of the time. For the way the majority of the Vette’s repairs have gone, I’ve had to balance price, availability, and delivery time. And then make plans for how quickly the repair can be done.
So for small parts with small prices, a $100 total to have them on-hand and available means no disassembly unless reassembly can be done same (or next) day.
I think we can all agree that @4-vettes makes a great point: diagnose, verify, repair or replace. And I think individually, we have unique budgets (time & money) to consider during those repairs.
In my case, minimal down-time is high on the list. So if I can remove an assembly and swap in a new one, I might not be saving money, but I’m saving time.
Old Apr 18, 2026 | 09:27 AM
The_JC_L46's Avatar
The_JC_L46
I considered this option, and then saw the price. I’ll put it on the wish-list!
Old Apr 18, 2026 | 08:57 PM
hdz28's Avatar
hdz28
I have that in another car, not my C3. It's a quality setup.
Old Apr 19, 2026 | 09:57 AM
stingr69's Avatar
stingr69
Just buy all the pieces. They are pretty cheap. 3 plastic seats, snap ring, ball studs, zerk maybe? felt seals, rubber seal ring, probably leaving some stuff out but you get the idea. Replace this crap while you have it apart. Done!
The cross shaft is pre-assembled with greased seats and outboard stud. Only 1 seat inboard inside the cross shaft. The outboard stud will be captive with 2 seats and a snap ring so the shaft can not move side to side. The inboard block stud will be tight in the block side threads but the block moves around vs the car frame while idling and driving so the inboard cross shaft connection is free to allow movement in-out between clutch linkage and engine block.
I do apreciate the cross shaft filler idea as it solves the problem of filling the whole darn cross shaft up with a ton of grease where heat melts the grease and then it runs out all over the place. Honestly, grease the pieces at assembly before install is my advice. Don't fill it all up later. If it needs service again in your lifetime, you know what to do.
Your "click" might be in the linkage or bellhousing fork stud or fork itself. The cross shaft rebuild might not get it gone. Still good to do this no matter what. The clutch linkage you can get to but the fork stuff requires dropping the transmission.
Old Apr 19, 2026 | 11:56 AM
drwet's Avatar
drwet
I will put in my vote for the Speed Direct clutch linkage kit as well. I have had it for years and it is a huge improvement over the stock setup. Your problem is probably in the linkage, not the the Z-shaft. Usually it is wear in the rods where they rub on the Z-bar since there is no lubrication there and GM didn't plan on these cars still being in service 50 years later.
Old Apr 19, 2026 | 12:10 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I think that if you were to remove the pin at the clutch fork and manually move the shaft and lever assembly through the full range, you'll feel if the "click" is in the linkages or not. If it's not, then I'm wondering if it's a throw-out bearing and clutch finger springs binding in some way.
Old Apr 19, 2026 | 07:57 PM
The_JC_L46's Avatar
The_JC_L46
Speed Direct kit is getting good reviews!
That's part of why I ask questions here on CF.
There's a good chance it’ll be a ‘this winter’ conversion. …in prep for spring ‘27.
Old Apr 19, 2026 | 08:09 PM
The_JC_L46's Avatar
The_JC_L46
One thing I forgot to add was…
I did engine mounts.
If (IF!) I stressed the cross-shaft and/or nylon seals/seats I may have caused it. That’s why I’m digging into the cross-shaft.
Pretty sure it’s unrelated, but I’d rather say it and be wrong than hold back and it’s actually the cause.
Old Apr 19, 2026 | 10:22 PM
The_JC_L46's Avatar
The_JC_L46
Great diagnostic tip to narrow down location!
Thank you @barkingrats !
That's a good separation point for:
Pedal-side vs fork-side [internal to trans/clutch assy]
Old Apr 19, 2026 | 10:43 PM
The_JC_L46's Avatar
The_JC_L46
I have (and agree with) the parts for replacement. It’s the “3 seats” that sold me unless anyone has rebuttals.
2 seats [outboard] have clearance for the snap (retaining) ring to fit -> minimizes transverse movement.
Inboard [engine-side] needs the ‘flex’ from torque/acceleration with a lil transverse slip. …as it should be/do.
This (and the ‘filler rod’ questions) were the ones I wanted to answer while chasing the ‘click’.
And if it’s not shaft/linkage, it’s in the fork/TO/clutch finger/sprong [hahaha] spring area. Internal to trans.
Old Apr 20, 2026 | 06:50 AM
stingr69's Avatar
stingr69
Still wondering why our cars originally came with a red plastic caplug in the cross shaft hole where we put the zerk? That's not a factory installed grease fitting.
Old Apr 20, 2026 | 09:49 AM
barkingrats
In the '67 Chassis Service Manual (which I'm sure is the same those before and after) it has this under the lubrication section. I also saw that GM recommended a graphite lube in the service section.
Old Apr 20, 2026 | 12:22 PM
drwet's Avatar
drwet
Typical GM doublespeak. Lubrication not required. Lubricate it at 36,000 miles or sooner. Who writes this stuff??
I have a zerk fitting in mine and I give it a squirt every Spring.
To Renewing Clutch Cross-Shaft
Old Apr 20, 2026 | 08:11 PM
barkingrats
Understood. I was just replying with the source of our Zerk fittings — that they're not factory but were dealer installed during service.
Old Apr 22, 2026 | 08:09 PM
The_JC_L46's Avatar
The_JC_L46
Merriam’s has it defined as: “occurring or recurring at a regular interval”. 36k is dependent on driving style, so there’s a hint of / inferred as “when it needs it”.
It’s 1979 and the 1969 has 22.5k on it, yeah, 10yrs without grease - it should have been done “sooner, if necessary”.
I get the impression that it’s a “by driver habits” “if the customer asks” “when the mechanic recommends” schedule.
The old 3k/3-6mo oil change idea isn’t periodic; it’s defined by mileage or time.
That's my take.
Old Apr 22, 2026 | 08:11 PM
The_JC_L46's Avatar
The_JC_L46
Speaking of the graphite grease recommended…
I posted earlier about opinions on chassis grease vs moly-grease. Any takers on sharing an opinion / use / results what brand / type?
Still thankful you guys are chiming in on my posts and offering good, useful advice.
Sincerely!
