My steering cylinder is loose at the relay rod attachment, with the castle nut tight the cylinder will still wiggle a bit, like a bad ball joint is that normal or worn out? do I need an alignment after changing this?
Reason: add info
Are you saying the stud is loose in the hole of the center link/relay rod?
Replacing the cylinder doesn't require an alignment but replacing the relay rod would require toe in adjustment.
Is the tapper loose in the relay rod? Or does the joint just feel loose. If the joint just feels loose with the engine off, that's pretty normal. It takes hydrolic pressure to tighten it up. Check again with engine running.
Thanks guys, stud is tight, the ball moves a bit with the engine off. I notice it has a spring in there, I will check with the car running next time I lift it. I suspect all is well. I appreciate the responses.
Are you referring to the power steering control valve not the ram?
If so, you can only check it with the engine running.
Well perhaps I misunderstood. The ram itself does need to pivot at its attachment. So, wiggles a little? Yes I wouldn't expect it to be tight. But how much wiggle are we talking about?
