Hello guys, I looked for info on this topic and could not find. If I missed it, please point me in correct position. Anyway, I have a 1982 that has a high Idle. When starting cold, it idles around 1400 and then will kick down to 1000ish when warm. In gear it will be roughly 900. I have adjusted the fuel pressure 11.5 psi, balanced the throttle bodies to 6 in of h2o. So it is running really good, just idling high. I also did this. With engine warm and off, I disconnected Rear IAC harness only. Started engine, idle went to 1500, Turned off. Left Rear IAC unplugged and then unplugged front IAC. Idle went to 2000. I turned off, plugged both back in and idle was 750. Thought I had fixed it, by somehow resetting the ECM. Went out today and I am back to 1000ish and 900ish in gear. Idle is smooth and performance is good. I hear that ECM controls idle, so not sure what to do from here. Appreciation in advance.
Have you looked in the diagnostic section of the 1982 factory service manual?
I don't have a scanner. Some more info. I took a reading of my TPS at idle. I can not get it lower that 1.2 volts. I have read that it should be .54 V. It does move slowly when I open up throttle plate...... I have also read in another thread to adjust initial idle on rear TB, but I do not see a screw. I only see the screw that adjusts vacuum.
You've got the balancing procedure half-way there (based on what you wrote). Your RPMs could be high due to not setting the TPS after balancing the throttle bodies.
Also, the recommendation for fuel PSI is 13. I have mine set to around 13-15PSI.
While you have got the 6inches (presumably on both sides), that is to set the baseline for air intake. Having it at 6inches will no doubt have you run a high RPM.
The correct procedure for balancing the throttle bodies is as follows:
Warm up to operating temp then turn off.
Disconnect IAC's on both TBs, plug air holes in the throttle bodies
Re-start the engine and put into drive (be sure to chock and set the parking brake)
Using the manometer, verify both throttle bodies are showing 6 inches, if not, adjust throttle stops until 6 inches is achieved.
Make sure to use the middle port on both throttlebodies
be sure to plug the vacuum port for the air cleaner thermac
Once balanced, the rear throttle body (driver side) needs to be adjusted down until the RPMs are at 475 RPM
I would not trust the tachometer on the car, mine shows around 150-200 off. Instead, I got an Innova tach/timing light
Attempted to use WinALDL as well but can't help but feel as though it sets the ECM to a mode that throws off the balancing procedure.
475 is the shop manual rpm. I have mine set to about 550 but looking to bump it up to 650 or so.
Put car into neutral, turn off engine
Use a multi-meter and set the Throttle Position Sensor to +/- 0.525v
If you don't have a connector between the throttle bodies, you can make one for fairly cheap or buy one (Xfire Performance) has them for about $32 + shipping.
Make sure that you check the bottom two pins of the TPS sensor. Anything else will give you an incorrect reading.
Remove plugs from TB's, reconnect IAC's
Restart engine, let run for a few minutes. The RPM's will idle high for a minute or two and then come down.
Take for a drive and get to 35 MPH for a little bit
Alternatively, connect a drill to the speedometer cable and get up to 35 MPH
Thank you klturi421 ! I read the same thing in the Shop Manual. I guess I am scratching my head as to why you adjust the rear throttle body to 6in H20 and then the Front to 6in H20, and then turn the rear down to lower idle. Won't that throw off the balance? I guess intuitively it does not make sense.....Since I have mine balanced at this point (although it was in park), could I not just turn the rear TB screw until I get desired RPM? If it is best, I will do the full procedure....as I am so close and have come so far....why not ??? I love the challenge ! Please advise and thank you.
MK
I honestly have a similar thought as to why 6 but I think it has to do with setting the idle. You get both to 6 to make sure they match, then when you lower the driver's side, the passenger side is lowered as well. Once balanced at 6 and you lower it, it should make sure that the throttle body gets enough air.
I would make sure you're in drive when setting the base RPM. I had it in park when I set it and it throws everything off.
A scanner is a must have for any fuel injected car. Just by looking at the IAC counts would tell you whether too much air is getting into the engine or the ECM is commanding the high idle speed. Anyhow 1.2 volts could be a bad TPS, out of TPS adjustment range from throttle shaft not fully returning, bad TPS ground. All sensor grounds terminate at the ECM, not chassis ground! It very important not to use chassis ground for sensors. Your FSM will show you where all the screws are and what they do.
Thanks Fly Skip up. I am going to rebalance the TB to 6" as suggested and then turn the Rear one down to get lower idle and then check the TPS voltage. I will keep you guys posted. I appreciate your help.
